Refrax mortar - any good and how far does it go?
  • OT-in-TN
    • Jun 2016
    • 27
    #16
    Don't quote me but I am sure someone as well will chime in but you would use the same mix ratio but use that ciment fondu as a substitute for the portland cement and you will have a true refractory mortar.
    • OT-in-TN
      • Jun 2016
      • 27
      #17
      3:1:1:1, 3 parts sand, one part ciment fondue, one part fire clay, and one part lime.
      • jonv
        • May 2015
        • 255
        #18
        OK, thanks
        • deejayoh
          • Jul 2010
          • 1893
          #19
          I was going to suggest that you might try Ciment Fondu instead of portland - but I can't recall any builders that have blazed that path before.
          +1 on the comment about getting fine sand. Makes a world of difference. Whatever you do, don't get "brickies sand", it has lots of large pebbles in it.
          • jonv
            • May 2015
            • 255
            #20
            Good tip about the sand! Think I'll do a bit more research on the fondu.
              Do not use ciment fondue as a substitute for Portland cement in the home brew. Fondue (calcium aluminate cement) goes off far more quickly than Portland cement so you have to make it up in much smaller batches. Lime acts as an accelerant with this stuff which will result in even shorter working time. Use the homebrew as advised.
              • OT-in-TN
                • Jun 2016
                • 27
                #22
                So could you make smaller batches and eliminate the lime?
                • OT-in-TN
                  • Jun 2016
                  • 27
                  #23
                  Refractory Fire Clay Mortar
                  Sand Calcium Aluminate Cement Fire clay
                  10 parts 3 parts 1.5 parts
                  • deejayoh
                    • Jul 2010
                    • 1893
                    #24
                    This is interesting - source not validated... But I do remember seeing the comment about the portland being burned away on this site before. David is resident expert on castable/refractory. I would take his advice.
                    FULL ANSWER
                    When using calcium aluminate cement, the recommended ratio for the materials is 10 parts sand, 3 parts calcium aluminate cement and 1.5 fire clay. If Portland cement is preferred, the recommended proportions for the mixture are 10 parts sand, 6 parts fire clay, 2 parts Portland cement and 3 parts lime. Portland cement helps the mixture to set but will be eventually burned off leaving lime, which is a type of calcium, to take its place.
                    • jonv
                      • May 2015
                      • 255
                      #25
                      I've never really understood what exactly the fireclay does - can someone explain?
                      • jonv
                        • May 2015
                        • 255
                        #26
                        ...and what the heck is the 'grog' I keep seeing mentioned in various formulae?
                          • 5260
                          #27
                          If you do a Google Search this is what you would of come up with.
                          • jonv
                            • May 2015
                            • 255
                            #28
                            So any clay, then, not necessarily fire clay.
                              Yes, for the temperatures we fire to any clay is suitable, although as clay imparts more shrinkage to the mix I'd be staying away from bentonite which has a very high rate of shrinkage due to its extremely small particle size. The clay makes the mortar more refractory (fire proof) and also makes the mix far stickier. The cheapest source of clay I can get is bricklayers clay, often referred as fire clay in the building industry. For a potter fire clay is an extremely refractory clay usually white in colour. Probably the cheapest powdered clay from a potter supplier would be ball clay.
                              • jonv
                                • May 2015
                                • 255
                                #30
                                Thanks for info. Learning more about all sorts of stuff I never thought I'd need to know
