Don't quote me but I am sure someone as well will chime in but you would use the same mix ratio but use that ciment fondu as a substitute for the portland cement and you will have a true refractory mortar.
Refrax mortar - any good and how far does it go?
I was going to suggest that you might try Ciment Fondu instead of portland - but I can't recall any builders that have blazed that path before.
+1 on the comment about getting fine sand. Makes a world of difference. Whatever you do, don't get "brickies sand", it has lots of large pebbles in it.
- 1 like
Do not use ciment fondue as a substitute for Portland cement in the home brew. Fondue (calcium aluminate cement) goes off far more quickly than Portland cement so you have to make it up in much smaller batches. Lime acts as an accelerant with this stuff which will result in even shorter working time. Use the homebrew as advised.Kindled with zeal and fired with passion.
This is interesting - source not validated... But I do remember seeing the comment about the portland being burned away on this site before. David is resident expert on castable/refractory. I would take his advice.
FULL ANSWER
When using calcium aluminate cement, the recommended ratio for the materials is 10 parts sand, 3 parts calcium aluminate cement and 1.5 fire clay. If Portland cement is preferred, the recommended proportions for the mixture are 10 parts sand, 6 parts fire clay, 2 parts Portland cement and 3 parts lime. Portland cement helps the mixture to set but will be eventually burned off leaving lime, which is a type of calcium, to take its place.
- 1 like
If you do a Google Search this is what you would of come up with.
http://pottery.about.com/od/potterygloassary/g/grog.htmRussell
Yes, for the temperatures we fire to any clay is suitable, although as clay imparts more shrinkage to the mix I'd be staying away from bentonite which has a very high rate of shrinkage due to its extremely small particle size. The clay makes the mortar more refractory (fire proof) and also makes the mix far stickier. The cheapest source of clay I can get is bricklayers clay, often referred as fire clay in the building industry. For a potter fire clay is an extremely refractory clay usually white in colour. Probably the cheapest powdered clay from a potter supplier would be ball clay.Kindled with zeal and fired with passion.
- 1 like
