Styrofoam Form for the vent arch?
  • Styrofoam Form for the vent arch?
    If I glue 2 pieces of styrofoam (4 inches thick) to make the template for my door /vent arches would the styrofoam be sturdy enough? I thought it might be easier to do this than using plywood. Plus it would be easier to get the styrofoam out.
    Let me know.
    Dick
    Re: Styrofoam Form for the vent arch?
    I would think that should be plenty
    Look here
    http://www.fornobravo.com/forum/f8/3...-pics-348.html
    It looks like the foam is only one inch and help up the dome during construction without a problem.
    Bruce
      if you feel it is necessary to have a second opinion... the styrofoam will be plenty strong...if you have any apprehension at all, use the blue or pink board, it may have a little more strength. But you will be fine in either case
      Bob
      Great pizza, a cold beer,a great cigar and great friends...my idea of a great time
        Don't forget to leave shim space underneath the styrofoam forms. A couple of builders had their arches fall trying to pull the forms out.
        GJBingham
          George, good tip. How long did they wait before pulling out the foam? I should think you can cut it to come out easier.
            So it sounds like the styrofoam will be strong enough to support my entry arches . I just didn't want to build it and have the arch "shift" while it was drying.
            I agree. My plan was to cut them out.
            TIP: I used an old "electic turkey carver" (actually a new one that we got as a wedding present 8 years ago but never used it ) with the two blades to cut the styrofoam.
            Dick
              Heavy duty plastic sheet works well for a shim over your formwork. Nothing wants to stick to it and form slides out easily. Also try to create what they call a release. That is a slope like a wedge so the form comes away easily.
                I used styrofoam boards for my archway - and I had to pull them early because of an accident with the vent pour, and I didn't have wedge thing and had to cut them out with a bread knife...
                But it worked out fine. Wouldn't want to use anything else.
                  Cutting them out is perfectly acceptable. A couple three shims under the bottom of the form can be easily pulled and the whole thing should come loose.
                  I think the current wisdom on how long to wait before pulling the forms is one week. If your bricks are custom cut with a keystone at the center, and with minimal mortar joints - 4 or 5 days may be safe. Why sweat it though. Give it a week. (I only lasted 6 days before I couldn't wait any more)
                  GJBingham
                    I used 1" pink foam board "arches" as my form or support for the vent arch. Plenty strong. Since I went with a cut brick arch, for minimal joints, I pulled the forms soon after getting all the bricks in place together. I wanted to make sure, if by some chance the mortar bond completely failed the arch would still stand. Pulled the supports and the the arch held fine. Great feeling. I should say the sides or wall were set of course.
                    Wade Lively
                      Good report Wade. I figured that with tight joints well placed bricks, the arch should stand on its own immediately. This is the point though that butressing the entryway walls might help a bunch.
                      GJBingham
