So I should've posted this a day ago, but I've already started my build..
I'm building a high dome 105 cm Pompeii, with an opening that is 12 inches high, by 20 wide.
my question is in relation to the vent landing mainly because I am confused as to where it starts and where it finishes...
my arch starts where the internal surface of the dome is 20 inches apart. Does the "vent landing" start at this point? Or, does it start at the point in the middle of the landing where the radius of the inner surface would've intersected?
Or, is the size of the vent landing irrelevant, so long as you can install an 8 inch flue?
i initially sized my dimensions by comparing to the Pompeii oven instructions, ' but now, I am a little concerned that I've made the space in front of the oven for the vent landing a bit too tight.
