Hi Guys,
I have a question on the taper of the inner Arch bricks. To be clear I am speaking of the side taper(wedge) to form the arch, not the back taper that is used to join the dome to the arch.
I have the HF saw which can only cut~3.5", so I am struggling to figure out how to cut the taper on the full 4.5" side of the brick? I have seen that some actually cut the brick down to 3.5" in order to complete the taper in one pass. I have been trying to do it in two passes and have not had much success as of yet, and I don't want to keep experimenting and using up bricks. Also adding a wedge underneath the brick to get the angle lifts the brick and reduces the amount of cut the saw can make
Any advice/tips appreciated.
