Which is better to fill the area between the oven and the outer structure, perlite or vermiculite?
Perlite or Vermiculite
The one you can source cheaper. There will be no measurable difference one vs the other -
Several builders who have dry poured P or V have blocked out the corners of the structure (with left over sheet rock or backer board) to reduce the volume of dry P/V in the corners where it is not needed.Comment
Or use empty plastic bottles with their lids screwed back on.Kindled with zeal and fired with passion.Comment
