Hi Chach,
Yes you will need to remove the bricks from each side of the entry and replace them with bricks similar to the ones in this picture, then but up your course bricks keeping the side arch bricks flat,
if you continue to go up with the course bricks when you are ready to start the arch you will not have a flat surface to start from, the arch needs to stand alone with the dome butting up to it, then tying in when you start you arch.
Sorry for the long winded explanation
Cheers
Doug
36" Pompeii Dome Chicago
I have builders block. i know you can build the arch while you build the dome and my plan was to do that until i got past the straight sides of the arch. my plan was once i got to the curved part i would just finsh the arch then continue the dome. I guess what im asking is im butting the dome to the form then cutting a triangle piece for the front for the reveal. is this not right and should i take out a few brick to do something else.
[QUOTE=RandyJ;n413142]Looking nice there. It is amazing how good the harbor freight saw is. I keep my pump in a separate bucket of water and it just cuts like a dream. I felt like i got money out of it on the first oven. And i am pretty sure it will do a second no problem at all.[/QUOTE
Thanks Randy! I bought a little bigger pump on amazon and longer hose and do the same thing I put it in a bucket of clean water and it works like a dream. Another item we think alike on lol.
Ricky
I was able to put some more brick in tonight on my birthday. coming along pretty good only working on this 2hrs max when I do and my 14hr saturday shift didn't help. I'm going to hopefully start the inner arch tomorrow so I can complete my courses of brick and continue going verticle. Im starting to notice the inverted V not real prominent yet but im thinking the 3rd course I'll have to start beveling the first inch or so if the brick to make it look straight. This is getting very exciting.
When i bought my harbor freight saw back in 2012 I never thought Id use it this much...i did 400 linear ft of retaining wall and cap with it brick pavers, tile work in the house, and now this project. I for sure got my moneys worth out if this saw.
I enclosed some pictures let me know if something stands out.4 Photos
Looking good. I know what you mean about life getting in the way when you are trying to get work done. That happens to me all the time as well. I was trying to grout a bathroom floor and had to stop in the middle this weekend. Hopefully you will find some time to get a few more set.
Well didn't get a whole lot accomplished. It seemed lile everytime I started I had to stop either for something with my family or the neighbor had some electrical questions which I ended up just doing the work for them which tool a few hours of my time. So needless to say I se t like 10 brick. But I at least got a feel for the IT how to position amd hold the brick. I will say that the homebrew mortar is some sticky stuff and it dries hard. Here a few pictures of my slow but happy progress
2 Photos
Thank you for putting this to rest for me...im not going to taper just bevel the front to get rid of the inverted V when that shows up. i was just thinking if a taper was done it would be a stronger build since the skinny part of the brick would be towards the inside of the dome amd the wider part of the brick would be towards the back. so if a brick slipped it would lock itself in unlike an untapered brick can just slide out..I guess im just over thinking. and I never heard of that happening to anyoneLast edited by Chach; 05-08-2019, 02:36 AM.
Not worth the effort, you might as well cut full bevel and tapers if you are concerned. Some builders have used left over wedge cuts to help set tilt, but left overs and cutting specifically for filling gap are two different time use resources. There is plenty thermal mass with mortar and brick, you need to ensure you insulate correctly and properly to take advantage of the heat.
Once you have filled the voids with mortar you are very close to the same thermal mass. Insulation and a good door do the rest and make the most difference.
Thanks, thats what im going to do..if it does not affect the oven's performance or strength then im good with it as well. Does the thermal mass get affected ny not having that extra fire brick there? just a side question Has anyone cut triangles out of fire brick to put in the gaps? I know I seen them do it on the arch instead of tapering but not sure if I seen it on the dome itself.
Yes, I did bevel only based what I had read in one of the "what would you do different" threads, where folks that had done both had said it was not worth the trouble. You can see in the pic that there is pretty much line contact brick to brick on the ID and it's easy to pack the gaps on the OD with mortar. The gaps tend to get much smaller towards the top if you are cutting the bricks thinner to keep the joints from lining up row to row.1 PhotoLast edited by JRPizza; 05-06-2019, 05:51 PM.
I agree with Randy, I did full tapers and bevels on my build just to prove I could. But it took a lot of time and effort. You are after tight inner joints and this can be accomplished by beveling the front side portion of the bricks where the two adjacent bricks conflict. Let mortar fill in the back side and underneath for tilt that your IT shows. I believe JRPizza did this as well. Also, you best work and bricks go in the back half of the dome and the adjustment of the front half. The front half is never seen again once the some is completed.
