Arch strong enough?
  • shanek
    • Jun 2018
    • 28
    Arch strong enough?
    May have jumped into the arch to soon and didnt think through it all the way. Im worried that the way i built it its going to push the side walls out? thoughts? a buddy suggested an "L" bracket to help support the sides but curious on everyone's opinion?
    • 5260
    Kind of depends on the chimney type, I have seen several of these type of configs that use SS chimney vents and "seems" to be solid enough. If you choose a masonry chimney then you definitely need to bolster the sides. You can add an additional stack of bricks along the verticals to bolster the side walls.
    • shanek
      • Jun 2018
      • 28
      I was also thinking of maybe drilling a 1/2 hole down the middle of the side briks to the concrete hearth (halfway through it) and putting a piece of rebar through it all. anyone ever done that? thoughts on if that would work?
      • shanek
        • Jun 2018
        • 28
        heres an example of what i did to test my theory
