Insulation
  • mleuck
    • May 2009
    • 31
    Insulation
    I am about to insulate my dome. The dome will be enclosed, so I am planning 2"-4" fire blanket with either loose vermiculite or vermiculite portland mix. What is your opinion regarding using loose vermiculite of the mix?
    Thank you
    Michael
  • mk e
    • Sep 2018
    • 95
    Everything I've read says pick the one that's easier or cheaper. If you're just filling up a space it's way easier to pour it in dry. If you need it to stay put like on an igloo you need cement unless you do some crazy hard form a hollow space construction. If you could pour it in but would need twice as much you can form a tighter space near the dome or just use cement and just put it on the dome. I dont think there is a right or wrong answer....but that's just what I've read.
    • RandyJ
      • May 2010
      • 1191
      I filled mine full of loose vermiculite and it worked great. It is east to do and provides a fair bit of extra insulation.
      Randy
      • cnegrelli
        • Sep 2012
        • 186
        If the dome is going to be enclosed, loose vermiculite is the way to go.
        • mleuck
          • May 2009
          • 31
          Thank you all for your help/responses. I am ready to move forward as soon s the hurricane moves on!
          • mrpubnight
            • Jul 2018
            • 32
            Good luck and hope you fair well through Florence.
            • George_M
              • Oct 2014
              • 290
              I put 2 layers of fire blanket and then i coat it with perlcrete.
              • RandyJ
                • May 2010
                • 1191
                If you are doing a enclosure then there is no need to do the perlcrete. That is just for a igloo style oven. Just build your enclosure and fill with loose vermiculite. If you can afford it you may want 3 " of blanket.
                Randy
