I reworked the brick placement to avoid the small triangle bricks abutting the landing bricks. I like this much more. I kept the herringbone for the cook area, but adjusted as needed to avoid small bricks around the perimeter that will be under the first course of the dome. Unfortunately, I ended up with 2 small bricks. I have an idea how to avoid those. I just need to think outside the box, or in the case outside 4.5" and 9" dimensions.
Thanks JR for the link. I'm been trying to figure out how to attach the pencil to the end of my IT. You gave me the solution.
Similar to you, I cut out brick templates from cardboard, rather than from 2x6s, to figure some of the brick placements. It helped me to avoid a lot of mistakes, but not all.
I made a template out cardboard that also helped with placement. Actually 2. I used one under the brick to protect the CaSi, and one on top to help with alignment and placement of the IT.
