With me it was the roof, took 2 years to convince my wife to apply her metal skills and for her to find the time..I had many types of suspended tarps and coverings , which blew off or were destroyed by snow load.. didn’t stop me cooking tho. 10 years on , still used every week , roasted 500 lb of coffee and at least 2500 loaves of bread!
37” Pompeii in SW ontario
Hi Jamel, I enjoyed following your build. It looks great and I'm looking to build one very similar. I noticed that you only used a 3in flue. I thought for the 36in oven that a 6in flue is recommended. Do you think that could have contributed to the crack? Thanks Roger
Hi Jamel,
I enjoyed your build too. Looks very neat. I at the enclosure stage. I see you used timber top plates and rafters - is that because you just prefer working with wood, and was it also because there were sufficient clearances to combustibles for code purposes?
Also, what screws did you use to connect the timber to the steed track?
Thanks for sharing your build.
Yes I went to wood for the top because at that point I had sufficient clearances ( as well as lots of insulation) and it was easier and cheaper for me to finish it off.
i believe I used regular deck screws to attach the wood top plates to the metal studs.
RickyMy Build Pictures
Fantastic work Jamel!! In SW Ontario too (Hamilton)! Just starting the build (base and all) - noticed you used foam glass under the ceramic board? Yes? I am trying to source that here and cannot find it - where did you get it?? Is it foam glass?
Also, how much tapering and angling of your bricks did you do course by course? Did you use the spreadsheet or cut brick by brick to fit? Look like they are largely half bricks, no?
Finally - can you show me a pic of your saw? I have a 10" Dewalt non-sliding compound saw and a 14" chop saw - not sure which to use/which would be best with diamond blade. Any advice here MOST welcome from your experience.
All the best - great build!
BarryYou are welcome to visit my build HERE
Thanks Baza,
I got the foam glass from C&I Crossroads. They have locations throughout Canada. Closest to me was in Kitchener. As for my bricks I ended up calculating each level of the dome and used a compound slide mitre saw to cut all the compound angles. It was a lot of work and probably a little overkill but Now that it’s done I’m forgetting how frustratingly challenging it was.
Actually the saw held up really good ( it’s just covered in sawdust). I purchased it used for $40 and it was already in rough condition but perfect for a job like this. I tried making my own compound angle jig but it was not rigid enough to give repeatable results. This saw saved me so much headache because I could trust the angles and making minor adjustments was a snap.
Finished one of the last tasks on this project! Finally! It has been quite the journey and I wouldn’t have been able to do it without all the great advice and experience I was able to gleen from this group. Thank you all so much!
I am still hoping to make an insulated door over the winter so we can expand the types of food we can cook but for now I am just happy it is done - and so is my wife
cheers to all and may your cheese never run outLast edited by jamel; 09-16-2020, 09:17 AM.
- 2 likes
