30inch Pompeii for a first timer
  • Mullster
    • Apr 2020
    • 193
    Hi Guys,
    So I thought it was about time to start documenting my build. Many of you have helped already just by sharing your experience via this forum - so hoping people can take something from seeing my build (and inevitable problems) along the way!
    I started out a few weeks back having done some research and watched several videos lumping for a vermiculite dome over a gym ball on a transportable stand. Dreams of spending less than £200, being done in a matter of weeks etc,etc. Well the more I read this forum, the more I considered how much I love pizza, and the more I realised there was something more I could build that would hopefully last longer and perform better - my plans changed and I decided to plunge into a full blown Pompeii brick oven. Unfortunately not before spending the best part of a weekend creating a gym ball dome jig I no longer need! (Pic below)
    Anyway - Friday marks the day the concrete slab completes - frame is in place with wire mesh and rebar and I’ve scaled down some of the measurements from the plans supplied here to accommodate a 30inch internal dome. Our garden simply isn’t big enough to take much more and it will give me enough capacity to feed the family and the occasional friend (only the best ones!)
    I don’t have a wealth of tools - although I really enjoy DIY I’ve mainly done woodwork to date so all the masonry stuff will be new learnings for me. Not having a compactor I made use of the paving slabs by putting them make down on top of the pea gravel for a few days - seems to have done a decent job of compacting.
    Another lesson learnt is about dog-proofing the work area! You’ll see that I had fashioned a curvy mould for the foundation slab - just about where my feet will be when stood at the oven, but the dog managed to get it and rip that off! The wooden frame is fine - so I might be back to simple rectangular shapes unless I can re-make before the concrete guys appear on Friday.
    Ive also sourced the bricks for the stand. Like someone else mentioned - with the lockdown I found it impossible to get the hollowed out blocks so I’m working with solid, but I think I’ve managed to plan a design with minimal cuts.
    So - looking forward to sharing progress and asking questions as I go along. You guys have built some beautiful ovens already so appreciate your support!
    Sam
    My cast oven build thread
    https://community.fornobravo.com/for...-castable-dome
    • 5260
    Since you do not have a lot of tools specific for building a brick oven and the diameter being 30" have you considered doing a dense refractory oven over a sand mold? As mentioned before, DavidS is our resident cast expert and does small diameter cast ovens commercially for sale in Australia. With a cast oven, you would only need a fire brick floor vs a floor and fire brick dome which require cutting, tapering and beveling fire brick.
    • Mullster
      • Apr 2020
      • 193
      UtahBeehiver Thanks for the suggestion - I’ll look into the idea of a cast. Is the Other Oven Types forum the best one for that then?
      Also are you aware of any posts that consider cast vs brick - sort of a pros and cons view of the two against each other?
        • 5260
        I believe David S recently posted a couple links to well documented cast ovens. Look at David S recent posts. There are so many variables in considering brick vs cast, ie budget, size, material availablilty, etc. You just have to search the forum and gather info.
        • Mullster
          • Apr 2020
          • 193
          DavidS I think I might be your next student!
            • 5260
              Try these well documented builds.
              After 4.5 years of lurking, I'm now about to build the WFO. I've worked out most of the materials and found pretty much everything I need. Some useful info on where to get materials came from DrakeRemoray and Coloradoredusa. In the end, Russel's advise of EJ Bartells (now Distribution International) for
              I've started the build of my 32" home-brew cast oven. I've removed the sod from the area where I'll be pouring a 4" thick slab. I'm planning for the slab
              • Mullster
                • Apr 2020
                • 193
                Right - going to start a new thread - taking on board all of the advice I’ve changed plans again and I’m now going to go for the castable dome! Got my foundation poured today - excited!!
