G'day All,
Wow, the time has come to start the build post. I have commenced the base support and plan to lay the hearth soon. Many thanks to UtahBeehiver, JRPizza, mpmckenzie, chach and david s who have provided terrific info so far. I certainly hope to continue learning from the forum and in turn pass on to those building in the future.
I do have a couple of questions and certainly appreciate the responses;
1 Searches suggest this is the best place for an ongoing build post. Please confirm this is still the case?
2 What is the purpose of a 'heat break'. I have seen in floors and have I seen rope seal heat breaks in the entry arch?
3 I've read lots and lots about dome on and off the floor bricks, however, what could possibly cause the need to replace a floor brick, right out on the edge? Also, the lower section of the dome would need to be vertical to allow installation of a new floor brick??
Kind Regards
Greg
Kind Regards
Greg
