Another insulation question
  • Gassman
    • May 2020
    • 16
    I am planning to build a 39" pompei. Planning on 4" calsil below cooking surface and 4" ceramic blanket on dome. Is 4" sufficient for the dome? I am planning to stucco over that. Trying to make it fairly fuel efficient. It will probably have a simple roof over it in the end. Thanks
    Member *********
    • 5256
    Plenty of insulation for multiday cooking. But sure to read threads on how to keep water from hearth getting in the floor insulation.
    • Gassman
      • May 2020
      • 16
      Fantastic! Yep, ive been reading about that for a couple days now. And it just rained to show me a slight depression in my cement. Gonna drill a series of weep holes. Entry is pretty protected from the elements plus i have a roof in mind. Thanks for the reply
        Member *********
        • 5256
        Need to have you start a your thread in Oven Construction rather than this subject.
