42" In South GA
  • Stlavsa
    Another alternative to having an exposed vent at the top of the oven is to ask moisture to exit through the flue pipe. By drilling a number of holes in the base of the flue pipe that is surrounded by insulation, moisture will find its way to the base of the pipe and exit with the smoke. See pic for explanation
    Wish I would have seen your post regarding this an hour ago. Just ordered some 1" copper pipe to construct a vent with china cap like this:guy https://www.youtube.com/watch?v=rqBkNOTdnUk
    I do think there is some benefit to having the vent at the highest point of the dome as well, I think it would be wise to incorporate your idea as well
  • Stlavsa
    Originally posted by edonovan View Post
    MarkJerling I am going to give your name to my wife …I don’t know that she can wait that long for my tarps to be thrown in the trash LOL…I think I can give it 2 and half weeks before the “big reveal” party. (Which we were hoping to have it painted for, but could possibly convince her we need to wait if it is better)… You think I am “trapping” a lot of moisture in the stucco if I do it that early? I am just doing a good exterior paint…not a “waterproofing paint”
    And yes I am reading up on doors, and deciding if it is something I want to tackle myself or find a local fabricator. I have been wanting to teach myself how to weld….could be an excuse to buy a welder.
    wait If you are using acrylic paint it should be breathable and you wont be locking in moisture?
    While stainless has a lower thermal conductivity than most other metals it warps badly with heat which can create sealing problems against the oven mouth. The thinner it is the greater the problem.
    Depending on how you construct your door and how it is insulated will impact how effective the door works, as far as metals aluminum/copper are not a good materials to use, very high K value, carbon steel is still high in K values, then SS is the least K value of common door metals but requires a tig to weld. You want the metal to be as thin as possible to reduce heat transmission and door weight. Some builders have used wood fronts with metal backs, not quite as durable as all metal. Leftover ceramic blanket or CaSi is commonly used to insulate the door but should be fully encapsulated to avoid food contamination. If the temps are low enough, wood doors are possible, but prone to charring and require rebuild and replacement. There is a thread out there on doors, so do a quick search.
  • MarkJerling
    Hahaha. Your wife and my wife can compare notes! LOL. Yes, I'd advise against painting so quickly. Think about how much water you put in the plaster and then consider that most of that water is still in there.
    I own a welding machine but have not yet learnt to weld so my doors are screwed and riveted. My "inter" door is insulated properly while my "outer" door is not designed to handle heat. It simply helps keep moisture out the oven. My wife was very happy once the ugly blue tarps were gone!
  • edonovan
    Originally posted by MarkJerling View Post
    Looking good. I'd advise against painting too soon. Let it dry out of a good few weeks or at least a month. There will be a lot of moisture in the construction. I left mine for almost a year before painting it.
  • MarkJerling
    ....;now letting this bad boy dry out for a week or so before painting it!!
    ....but does that mean I need to do a whole drying fire or just go slow as I come up to temp? Or will I just notice that it takes a little longer to heat up?
    Yes, moisture gets in, but I find that it simply means that you need to make a "slower - longer" fire to dry things out for cooking. Keeping moisture out was a problem until I made my "outer" door as I had some wind-blown rain getting in before.
    As an addendum to my previous answer, if the oven is wet and I am only cooking pizza for the family or doing a roast, I wouldn’t bother doing the slow fire the day before. Only if I was planning on having a fair number of people around. The oven will still operate ok, just not quite as efficient.
    Normally the outside of the oven will be just cosy warm during operation. When that cosy warm has spread down to the base, the oven is ready for pizza. If the insulation is moist however, it will feel hot to the touch on the outside.
  • edonovan
    david s yes, I am/do over worrying…it’s something I tend to do…my wife loves it lol …I also tend to “overbuild” things…I have weep holes and my cal si board is on busted up tiles, so it has a way out…it’s more through the stucco and perlite layers and like you mentioned the humidity. In my head I know it will be all right…I just…you know double check. Lol… thank you for the insight about just a low slow fire the day before a cook if the oven has seen a lot of rain, that’s what I was thinking and hoping.
    After doing all the initial slow fires you don’t need to go right back to repeat them if the oven gets wet after heavy rain. Just a couple of long slow fires are sufficient. Most ovens are out in the weather. We live in the tropics and the oven can get wet just from the humidity in the atmosphere. A slow fire the day before seems to do the trick. I think you are over worrying the issue. Do you have a drain hole(s) through your supporting slab to allow under floor insulation moisture an exit path?
  • edonovan
    Well, I definitely am not the best shaper…but not too shabby for a novice stucco-er… left a plastic drop cloth over this for 3 days to get nice and solid…now letting this bad boy dry out for a week or so before painting it!!
    Hope to get some granite placed in to have level counter tops throughout…he stopped by yesterday and will get back with me about how close he thinks his installers can get due to my sub-par shaping and them having to bevel the stone pretty good to leave as small of a gap as they can. I guess if I need to build up the bottom 4” of the dome so the stucco is a bit straighter then I can have a better fit stone around the dome, and a smaller joint line.
    I do have a question for those that have an oven out in the elements…mine is under a cover/roof but corner build and I am in the southeast…good summer thunderstorms will drive a little sideways rain, and my wife is counting the minutes for me to get rid of my blue tarps…and I think I may cry the first storm we get and the oven gets rained on. My question is what to expect after a good storm? Obviously, some moisture will find its way in…but does that mean I need to do a whole drying fire or just go slow as I come up to temp? Or will I just notice that it takes a little longer to heat up?
  • edonovan
    After a bit more research and thinking about the “waterproofing” I decided against Drylok, couple reasons…after reading other threads and the “if you are locking it out…then you are locking it in” didn’t sit right with me from a moisture perspective (still doing a vent)…and Drylok is not very friendly with UV, and the right side of my oven, even though it is under a roof, gets blasted by the morning sun. So I am going with valspar exterior flex-shield 365, it is 100% acrylic which from what I am reading is good for weather and UV…As I said above, the oven is under a roof, but a good sideways rain will get that right side pretty good.
  • edonovan
    Ok, well my first “eyeballed” layer of pecrete was definitely too wet…measured the rest of it out and yes slightly more challenging to handle, but got the hang of it and got in a groove!! Pecrete finished!!! Will let this dry out and hit the stucco layer.
  • edonovan
    david s Thank you, I wanted to make sure I wasn’t going to hurt or crack my pcrete…I know to wait about a week until I stucco, but wasn’t sure about having a good fire in there once the pcrete was laid.
    If you've got the blanket layers on it's fine to go for another pizza cook up.
