yes normal cement. the temperatures that layer will feel are well within normal cement's capabilities. For powdered clay the cheapest is Cement Australia's Bricklayers Clay. If you can't find that try Potery Supplies and get a 20 kg bag of Ball Clay.You'll need the clay to make the home-brew mortar as well as the small amount in the vermicrete mix.Last edited by david s; 12-21-2020, 03:43 PM.Kindled with zeal and fired with passion.
Crisis averted thanks to david s
So yesterday finished my first layer of 25mm thick perlite. Will leave it "dry" for a couple of days before i add my next 25mm layer.
Not sure if people have heard this before, but it was suggested to ne by a refectory "expert" to wet the perlite in the first few days to help it cure.
2 Photos
Vermicrete insulating slab copy 2.pdf No need. Because vermicrete or perlcrete requires so much water in the mix there’s plenty of free water hanging around for sufficient damp curing. Only about half of the water added goes into the hydration process so there’s plenty left.Even in dry conditions you need to wait more than a couple of days drying. As the strength of the layer is hardly a consideration, it only needs to be strong enough to act as a firm substrate for the outer render. When the stuff goes from grey to white , you’ll think it’s dry, but it won’t be underneath. You really need to give it a week to dry.
Read my experiment on drying a vermicrete slab to give you an idea how slow it dries.
By the look of your pic your mix is way richer than 10:1. Remember that the more cement you use the less it will insulate. It is especially important to let it dry completely if you are applying it directly over the dome rather than over blanket as any moisture there will rapidly turn to steam creating problems. A layer of blanket takes the sting out of the hot dome, working like an expansion joint and preventing sudden heating of the perlcrete layer.Attached FilesLast edited by david s; 12-23-2020, 05:31 AM.Kindled with zeal and fired with passion.
The little attached table gives you the insulation value for various mixes. The 10:1 mix should look like the attached pic with visible voids between the perlite grains. Just make your next layer leaner for more affective insulation.
2 PhotosKindled with zeal and fired with passion.
So ended up finding more premix "vermiculite" (photo attached).
1. So since my last post have managed to finish the 2 layers of 25mm "vermiculite"
2. Have also completed a number of slow burns to dry out the "vermiculite".
3. Tile work around oven on the bench
Now waiting on chimney flue and attachments to arrive6 Photos
So, now ready to add a 50mm layer of cement render over the top of my rockwool.
Question though what mix have people used for their render?
At this stage I am thinking of using a sand, cement, lime mixture with the ratio of 6:1:1 Apparently the lime gives the render some elastic properties and reduces cracking ( found this on a rendering website). What do people think?
Also, have been reading about "vent holes" for the water vapor. Am interested to see what people have done and if they are really necessary.
The finish line is getting closer !!!!
You are using rockwool as an insulator over the dome and then plan on a render coat over it?Originally posted by Hatzi View PostSo, now ready to add a 50mm layer of cement render over the top of my rockwool.
The finish line is getting closer !!!!My Build:
So, you compressed it? If so, that's not a very good idea. Is there a reason why you used it there and not ceramic blanket? Just curious.My Build:
I suspect that you will get compression to some degree with either product. I am using a product that WFO manufacturer suggested.Originally posted by NCMan View PostSo, you compressed it? If so, that's not a very good idea. Is there a reason why you used it there and not ceramic blanket? Just curious.
If you look at UtahBeehiver build , there is a debate in his thread about the layering of the dome and when to use the blanket. When reading through the thread and doing some research, it seemed to make sense to me use teh blanket over the top of the vermiculite and then have the render on top of the blanket.
My WFO will not have a separate housing as is seen in many builds in colder climates.
david s
oasiscdm
UtahBeehiver
what do you guys think?Last edited by Hatzi; 01-08-2021, 08:04 PM.
Hatzi i just used premix bags of light weight render. Costly option. Then i used a spray on granite mix for decorative finish
I drilled 6 holes in bottom of hebel to the calsil board only.
