Hi Everyone,
My name is Jonas, living in Belgium. After reading and reading for months on this forum, I started designing the oven I want to build.
Attached you can find 2 pictures after some trial and error in Sketchup.
My questions for now:
Some key dimensions can be found on the pictures, as a summary:
- working height: 95cm
- inner diameter dome: 100cm
- outer diamater dome: 140cm (incl 10cm brick, 5cm insulation, 5cm outer layer)
- height oven dome: 50cm
- With arch = 55 - 75cm (incl bricks).
- height arch = 35 - 45 cm (incl bricks)
- depth arch = 22cm (not sure yet about this dimension, probably not enough for the flue)
The walls will be made out of hollow concrete blocks that I will fill with concrete and steel bars.
The table top on the left:
- OR a concrete top that I will finish with something. I should be able to make the pizzas on this table, so should be easy to clean and flat.
- OR I'll buy a table top from the store and mount it on the walls. Do I need to foresee extra support in the middle of the table? Or will this be strong enough? How thick should the table top be?
Any advice/feedback is more than welcome!
Regards,
Jonas
- the concrete slab will be 25cm thick and the concrete table top below the dome will be 15cm thick. Any advice is this is too much or not is welcome.
- Under the dome, I've foreseen an extra wall to support the whole construction (marked in red on the picture). Is this actually needed or not?
Regards,
Jonas
