Re: Les' Build
Les,
You have to stop to slow torture the community and have to finish your dome!!!
Please!
Les' Build
Re: Les' Build
Les....it's a shame you and Ken had to cover such great domes....but it makes me happy since they look more like mine now on the outside
Why is your cladding mortar cracking? What did you use? Were the dome bricks wet down first? I find that using a damp/wet brush over the mortar helps to spread the cement and minimize the cracking as well as slows down the drying to let it cure.
Looking forward to your fires!
JimLeave a comment:
Re: Les' Build
Les,
Just amazing. The coolest thing about this is that once it's insulated, it won't matter in the least how much your mortar cracks. I think you've come close to building the perfect dome.
Thousands of years from now, archeologists will be convinced that aliens came down and lent you a hand in building this!Leave a comment:
Re: Les' Build
Your legs are nothing compared to your brickwork. Very nice (the brickwork).
JamesLeave a comment:
Re: Les' Build
(copied from the gallery for the record)
Kinda ugly - my mortar at this point is about 1/8 inch thick - cracks very easy. I was trying find the perfect circle (not the band) but some of the brick started to chip - good enough. I really think I will be able to set the keystone this week - take time off for the 4th - then bring on some major fire.
Les...1 PhotoLeave a comment:
Re: Les' Build
Les, I feel ya...mines still in college and all manual labor is not her......try the guilt trip
and yes, we all would rather see your wife's legs
. (no disrespect to your legs, of course)
RTLeave a comment:
Re: Les' Build
James - I think you would prefer a picture of my wife's legs sticking out
RT - my daughter just graduated from college - masonry is so not her
I may avoid the chamber altogether (and my wife) - I drew a template that may work for the inside cut - then it's just a grout bag from done. I ran 2 bricks shy of getting it done tonight. Up my brick count to 277.
Thanks guys!
Les...Leave a comment:
Re: Les' Build
Les, daughters also work very well for that inside the oven work. Besides being small and thin (excuse me, petite), which I am not......she owes me (at least thats what I told her).....surprisingly she slid herself right in and prodeeded to do the final pointing and cleanup.
RTLeave a comment:
Re: Les' Build
I think I can avoid it altogether - I may have my wife convinced that she needs to be inside when I set the brick.
Re: Les' Build
RC - I responded to Dutch's question (link #19). I really don't see a lot that can be done in that area other than slinging mud or hanging brick - either approach doesn't seem to me to be an improvement. I'll take a look at it when I have to crawl in there for the keystone (ONE time only).
Jim - I noticed your question about a soldier course - I didn't see a real benefit doing that and I was after the "perfect arch". I may be dead wrong after I start cooking, don't know yet.
All... thanks for the complements, appreciate it.
Re: Les' Build
Impressed with Les' work I went to the beginning of the thread to see the progress. When I went back to fix my crack that started at the side of the door and went up, I decided to redo my vent opening and also to reinforce this void area under that course at the door. I stopped after two supports that went in the gap (to much working upside down) and used several thin layers of refmix to fill that void.Super fantastic, Les! That was a lot of "using your noodle" as a friend of mine always said! How are you going to handle those little voids under that course at the door? You probably don't have to but with the attention to detail that you have shown so far I thought you might have a plan in place already!
Best
Dutch
I'll be real interested seeing responses to Dutch's question.
Les, did you appreciate the raise once college tuition was over
Re: Les' Build
I still think it looks like magic... either that or trick photography.
Very very beautiful!Leave a comment:
