36" Build Alberta, Canada
  • Vee
    They are glued with PL600. Dome enclosure bricks will sit on top of the counter levered bricks of the hearth to provide extra stability. Here is what I was planning.
    I was aiming for a floor height of 42" but could build a taller pcrete floor by 2" but that would ​bring me up to 44" floor height. Is that getting too high. I'm only 5'7"!
  • fox
    Have you stuck all the bricks together with adhesive or do you plan to cement them together ?
  • Vee
    Russell,
    Thanks! Maybe I'll drop my plywood floor down a couple of inches to make room for a larger pcrete base.
    5 to 1 pcrete is typical for floor insulation with 4" of pcrete roughly equal to 2" of CaSi board and is the "minimum" recommended floor thickness Click image for larger version  Name:	Vcrete K values.JPG Views:	0 Size:	159.3 KB ID:	439255
  • Vee
    started a topic 36" Build Alberta, Canada
    Hello,
    After months of lurking, I finally started my 36" build at my cottage. Since I'm only there on the weekends for the most part I used landscaping blocks to speed up the stand build. I'm about to pour the concrete for the hearth. I have 8"'s to play with for the concrete slab and perlicrete base. I was planing on 4" concrete and 4" perlicrete. Would it be better to go 3.5" concrete and 4.5"'s of perlicrete to maximize my floor ​​insulation? Is it better to add slab strength (69"x 54") or floor insulation?
    Starts
    06-17-2021
    Ends
    06-17-2021
    Location
    calgary, ab
