38" Pompeii build
  • #46
    I use a similar method using a template. The whole back of the oven is then pretty much covered in one single piece, using the off-cut triangles to fill any gaps at the base. Very little wastage and the blanket sits in place by itself.
    Click image for larger version  Name:	IMG_2030.jpg Views:	0 Size:	170.4 KB ID:	468494 Click image for larger version  Name:	IMG_0364 copy.jpg Views:	0 Size:	58.9 KB ID:	468493
    • #47
      Very nice, david s!
      • #48
Name:	IMG_0855 Large.jpg
ID:	468553 I managed to find a couple of hours a couple of days ago, wired the insulation, fitted mushroom cowl, and first layer vermicrete. Since lit a hotter curing fire (dome getting to 250C now).
        JRPizzas suggestion about lath was good, but the lead time was long for me by mail order and I already had chicken wire and vermiculite so I just cracked on with it.
        feels like progress.
        vermicrete is weird stuff isn’t it! Got a bunch more to do.
