37" Oven Build Stats from start to finsih
  • ultrasport
    • Jun 2021
    • 27
    This is a build I just completed from ground breaking to final oven with the following stats:
    Build Time-8 Months /approx 500 hrs --- Cost approx $4000.00
    Base thickness 8"
    Dry stacked block veneered with full size standard brick
    Floating slab-5" thick
    Oven Floor Base- 5" Vermiculite/ Portland mix topped with 2" rigid Calcium Silicate board
    Oven Floor-- Smithfield Medium Duty Firebrick 9 X 4.5 x 2.5 --imbedded in Fireclay--Herring Bone Pattern
    Oven Dome-- 37" Inside dimension - Same brick as floor
    Dome Covering--3-1" layers of Fire Blanket #8 --1 1/2 " Vermiculite/Porland mix--1/2" Stucco hard shell--Covered with tile and sealed
    Flue-- Clay 8" OD square ID 6"
    Door-3/16" welded steel plate with 1 1/2"insulated chamber
    Roof --wood frame--Steel Roof
    These Stats listed are just the basics of my build. If interested I will try to answer your questions . I have almost every step documented with photos.
  • Macrinehart
    • Jan 2022
    • 175
    Looks great! Nice view!
    My build thread: https://community.fornobravo.com/for...-pdx-42-update
    • fox
      • Mar 2017
      • 388
      Well done looks really nice.
      • deejayoh
        • Jul 2010
        • 1893
        I like the way you incorporated the roof with the dome. Great design and tile work
        • Buzzard Bluff
          • Apr 2021
          • 31
          Terrific Job....
          And ditto on the nice setting!
          • ultrasport
            • Jun 2021
            • 27
            Thank you very much..Marinehart, Fox, Deejayoh, Buzzard Bluff
            That's High Rock lake, NC in the background
