The kit comes with enough blanket to do 2 – 1” layers. The 1st layer rests on the CaSil board and the other is intended to rest on the concrete slab. I wanted to keep the CaSil and blanket away from the slab so that’s why I added the FOAMGLAS with 3” extending beyond the CaSil. I purchased 2 more 50 sqft rolls of blanket with the intent of having 4 layers, 1 resting on the CaSil and 3 on the FOAMGLAS.
Though I had done the math, I wasn’t sure I would have enough to do 4 layers as I had planned. I decided if I was short I would just put as much of the 4th layer as I could starting at the top of the dome.
The 1st two layers were wrapped horizontally per the kit directions. I found that difficult to manage with one set of hands. I switched things up and laid the rest by wrapping vertically. I had enough for 4 full layers with about 15 sqft to spare. That was probably roughly the area of the entryway x 4.
Weather at this time of yr in central PA is interesting. It can be over 80oF during the day and frost warnings at night. I picked a day in the low 60's to do this work and it was uncomfortable wearing all the garb. Didn't finish and started early the next day. By the time I finished it was 86 and I was cooked! So, plan your work accordingly. I wish now I had just set up some lights and worked into the night on the first day.
The kit has 5” nails to use as anchor points for the fine wire that snugs the blanket to the dome. These were useless to me because of the extra layers. I found some 8” Headlock screws in stock at a local big box store. These worked very well. I screwed them through the blanket and into the CaSil, see pic #2. I wasn’t keen on introducing more metal but couldn’t think of an alternative. There was enough wire despite me increasing the surface area.
Lastly, a roll of chicken wire is hooked on those same screws and wrapped over the dome to serve as something for the pericrete render to hold on to. This is one of those additions that’s debated on the Forum. Some advocate its use, others say it’s not necessary to support the pericrete and it adds more conductive material in the insulation layers. I think it also depends on the thickness of the 1st layer of pericrete as well as the consistency of the mix. I felt I should follow the kit instructions and use it and wasn’t super concerned about the heat conduction with the 4” of blanket.
It's crazy after all this research that I’m still thinking on how I’m going to finish the dome. So, I’m going to have more questions on products for you and the others on the Forum
