Thanks xvandish. I still have cosmetic finishes to do and build a pavilion plus some landscaping, but I'm going to enjoy using the oven this year.
This is my first go at non-pizza in this beast. It’s going to be fun learning how best to use it for retained heat cooking.
I haven’t yet fabricated an insulated door. I noted the temps every 12 hours after firing for pizza. I waited until the flame died and there were just embers then placed the steel door that evening. The probe end of the thermometer is about 2.75” from the inside face of the dome so it should be a good indicator of heat saturation of the brick. I typically keep my fire on the opposite side of the dome from the thermometer so the increase in temp the next AM is a good indicator of the dome coming to equilibrium via conduction.
All of the starting temperatures were higher than I normally use so everything baked faster than normal. Next time I’m going to try cracking the door to bleed some heat while cooking.
07/02 2100 475oF (246 oC) Closed oven
07/03 0900 525oF (274 oC)
07/05 0900 290oF (143 oC)
07/05 2100 260 oF (126 oC)
07/06 0900 220 oF (104 oC)
07/06 2100 200 oF (93 oC)
07/07 0900 180 oF (82 oC)
07/07 2100 160 oF (71 oC)
It's cool that I can use commercial full-size sheet pans.
Really happy with the heat retention. Not sure if I even need to fabricate an insulated door. It seems as though the front of the oven is a little cooler, so an insulated door may help with that?? Still a lot to learn.
4 photos total
Sourdough bread on parchment on the oven floor
07/03 2100 500oF (260 oC) Hamburger rolls for the 4th on sheet pan raised on cooling racks.
07/04 0900 460oF (238 oC)Cornbread in cast iron skillet
07/04 2100 340oF (171 oC) 07/05 0900 290oF (143 oC)
Dehydrated fruit
07/08 0900 140 oF (60 oC)It's cool that I can use commercial full-size sheet pans.
4 photos total
I went to mostly baguettes for my giveaways because I could bake a batch of 8-10 at a time & each batch was done in 15 minutes at 575F. You'll also both appreciate not having to fire up the inside oven during the hot days of summer! Don't forget to try making your own granola as the oven drops into the lower temp bake zone. I also highly recommend trying the corn in the husk technique that Gulf posted a ways back...Possum Korn in the Roasting & Grilling section.
. I had forgot reading about Joe's Possum Korn. Thanks for the reminder.
. Fortunate to have an architect daughter to plan it.
