31"/800mm in Eindhoven, the Netherlands: Design critique and build topic
  • Giovanni Rossi
    • Mar 2021
    • 310
    #16
    Toiletman , it's sometimes tough seeing detail with photos because of lighting and angle, but it does look like there is a fair amount of difference in the height of some of the bricks 3-4 away from both sides of your IT. Randy is right, most often it will just work out with random placing. You'll just have more visible mortar joints here and there. Remember, you're going to be able to see only a small percentage of the inside of your dome unless you crawl in. Again, maybe it's not as dramatic as it looks, but I'm surprised at the differences in what is probably the same manufacturing run.
    The one thing I'm thinking is, if you happen to have groupings of the shorter (or taller) bricks match up in 2 rows, it could throw you out of level enough to make difference. Would it be too crazy to sort your bricks so you have enough similar height ones for each row?
    • Toiletman
      • Sep 2023
      • 105
      #17
      RandyJ
      Giovanni Rossi ,
      Thanks for your input and sorry for the late reply. I've been crazy buzy with work and tried to put every spare hour into the oven. Indeed I was wondering about the thickness difference between the bricks. It seems to be in the 1,5-3mm range. To prevent tolerance stackups going out of control I've gone and selected them to low, medium and high bricks, and made sure not too stack extremes on top of each other and indeed now on the 3rd row it nicely evens out. I'll bring the leveling laser in for the next round to see if I'm out of level, but eyeballing it so far it looks pretty good.
      It's been slow going here, but now I've finally laid the first three courses in the mud it does feel 'real'. Learnings so far:
      • It's quite a bit of jiggling with brick drying time after submersion & homebrew water amount. For normal bricks the recommendation was to soak and afterwards leave to rest for 24h, but that's way too much for my firebricks. Leaving them at rest for 2-3hrs seems more ideal. Otherwise I feel they immediately suck all the water, and therefore 'flow', out of the mud. Ie: it's impossible to bed the bricks down if they (and the mortar) are not on the wet side as compared to 'normal' bricks and mud. I think my first course was too dry, the second one was ok, and the third one slightly too wet, so probably I've now found a sweet spot.... until the angle gets too large and bricks start slipping
      • The amount of 'overhead' that I'm going through now as compared to laying the bricks is quite high: sieving the ingredients of the mortar, cutting and selecting the bricks, detailing and cutting the arch bricks. It's slightly getting to me, but in the end it's a hobby project, so I'm just taking my time and enjoying the result. But for the people considering between a kit and the homebrew approach: definitely something to think about
      • I've not fitted my IT with a clamp yet, so far it's working quite well without, after getting used to it.
      In the attachment some pictures of the current status.
      I do have some questions about the bricklaying, hopefully you guys can shed some light on it. See especially the 2nd and 3rd pictures:
      To be able to bed the bricks down I'm trying to not put too much mortar under them. I also 'butter' them with a slight layer on the side, and then bed them down. This results in some gaps as you can see in the picture:
      in Red: the 'thin wedge' under the brick doesnt get fully mortared in
      In Blue and green: the vertical gaps are sometimes quite emtpy, without a lot of contact (this has gotten better in the third layer, with a slightly thicker 'buttered' layer, and a wetter brick and mortar.
      So questions about these gaps:
      Do they matter?
      Structurally my feeling is that there's more than enough contact with mortar to glue the bricks down, as well as the weight and dome shape keeping everything in place?
      Thermally I also feel that it would not matter a lot as the main heat flow is inwards->outwards. It might impact the thermal mass a little bit, but the majority of that comes from the bricks anyway.
      Visually only the vertical gaps on the inside of the dome matter, so for those ones I've pointed them to look good.
      I've now spent some effort to also fill the gaps on the top and on the outside of the bricks, but my feeling is that that might be a waste of effort? What do you guys think?
      If the weather lets up I might have another course in on wednesday, but probably it's only going to be cutting the bricks.
      Only dead fish go with the flow
      • Giovanni Rossi
        • Mar 2021
        • 310
        #18
        Do they matter?
        Toiletman There are fellows here with infinitely better masonry skills that I possess who can give you more peace of mind, but here's my 2 cents.
        As with a brick and mortar wall, I don't believe you have any issues regarding structural integrity. Maybe others could comment on the possibility of spalling of the wider mortar joints in this high-heat environment. My research led me to trying to make the mortar joints on the inside of the dome as narrow as possible. I worked each brick until I felt brick on brick contact. One of the most problematic things I faced was getting proper consistency with the various cementitious products I used. In order to get the tight joints I wanted, I had to keep the mortar on the wet side. Balancing that with the proper wetness of the bricks was challenging. My technique was to lay a mortar bed for 2-3 bricks and butter the side of the last brick I had set. It was too awkward for me to try to butter a brick before or after I clamped it in the IT. That mortar consistency certainly helped with getting brick on brick contact and squeezing mortar into those tight places. But, I believe I paid a price as the rows became more vertical since I had trouble keeping the bricks in place until the mortar cured.
        I wanted to maximize thermal mass so I filled the gaps. I typically had a little mortar left over after setting the last brick, so I filled in where needed. However, I didn't have the up front labor for my mortar. Heck, I had enough mortar mix left over that I was able to apply a 1/4" layer over the entire dome.
        You're making good progress. If there's anything I've learned from following this Forum it's that these projects are pretty forgiving. Like you said, yours is a hobby project, so enjoy the ride.
        • RandyJ
          • May 2010
          • 1191
          #19
          Toiletman i just had a chance to look at your pictures colser. You want to make sure that you are packing the space between the bricks full of mortar. You do not need to have the super tight joints all the way back on the brick. The front edge is where you want to have the nice tight joint and it is not as critical as you move back. I believe that you do want to have the joint fully packed full though. I see your bricks do not look to have any mortar squeezing out of the joints. You want that then just clean up the mess after you are done for the day. Sometimes it is hard to get the mortar all the way to the front of the brick but it is worth a shot. You can use a deadblow hammer to tap the brick into place. I would definitely recommend going through and trying to pack as much mortar into the joints you have done already as possible. It will make for a stronger finished product. This is one of the reasons that if i ever was to cut another oven I would just bevel the sides and leave everything else square. So much easier to make sure the joints are full. The problem is it makes laying the bricks harder and cutting them harder to try to keep all the joints tight. I know a few have done it but short of that being your goal for personal reasons it will not make a difference in how it performs. As long as you are not using something like heatstop as a mortar as I believe that requires tighter joints but still the back side does not need to be as tight as the front. Make the front fit tight and don't worry about the back. No one will ever see it. You will also want to make sure the front side in the oven is packed full for the joints you have the just wash it clean when you are done. I know I need to crawl inside mine now and touch up a few spots. That is just part of the game.
          Randy
          • Toiletman
            • Sep 2023
            • 105
            #20
            Originally posted by Giovanni Rossi
            As with a brick and mortar wall, I don't believe you have any issues regarding structural integrity. Maybe others could comment on the possibility of spalling of the wider mortar joints in this high-heat environment. My research lead me to trying to make the mortar joints on the inside of the dome as narrow as possible. I worked each brick until I felt brick on brick contact. One of the most problematic things I faced was getting proper consistency with the various cementitious products I used. In order to get the tight joints I wanted, I had to keep the mortar on the wet side. Balancing that with the proper wetness of the bricks was challenging. My technique was to lay a mortar bed for 2-3 bricks and butter the side of the last brick I had set. It was too awkward for me to try to butter a brick before or after I clamped it in the IT. That mortar consistency certainly helped with getting brick on brick contact and squeezing mortar into those tight places. But, I believe I paid a price as the rows became more vertical since I had trouble keeping the bricks in place until the mortar cured.
            Thanks for your input and I fully recognize your struggle with the correct consistency of the mortar and the correct wetness of the bricks. It's quite challenging. Further input below Randy's comment.
            Thanks for your input as well Randy, I"ll try and get all gaps filled in the coming rows. I just had another look at Ben's Firebrick video on the bricklaying and ordered a pointed trowel as well as a deadblow hammer, my large masonry trowel doesn't let met get close. Ben is also putting hte mortar on the existing row, instead of the new brick, that's what I'll also try.
            My doubt from seeing Ben's video is that my homebrew mortar does not behave like that at all, I don't think it will flow as much, but instead just transfer the hammer force into the bricks underneath. He also hammers in the bricks sideways, which I accidentally did on my first row. This resulted in the whole row shifting a little bit, so I don't plan to do that at all. Didn't you suffer from your other bricks moving while trying to push in the current one?
            • Giovanni Rossi
              • Mar 2021
              • 310
              #21
              Toiletman , you may want to try a technique I got from Russell ( UtahBeehiver ). At the end of your work day, mortar a single brick on your next row and allow it to set overnight. Then, you have a solid anchor to work the next brick against when you start your next work session. Since I didn't lay a lot of bricks each day and I needed to brace each brick the higher I went, I took this advice a little further and worked on multiple rows at a time. At one point my dome looked like steps of a pyramid, but I always had a solid section to tap against.
              • Toiletman
                • Sep 2023
                • 105
                #22
                That was a fantastic tip, thanks! Not so much visible progress here, but a lot of bricks were cut:
                • closing brick course 3 to arch
                • closing brick course 4 to arch
                • 4th course bricks
                • 5th course bricks
                • inner arch bricks
                Besides I followed UtahBeehiver's tip and put in a pyramid of bricks on the 4th and 5th course. The next day it was much better to put in a number of 4th course bricks. This time fully into the mortar: bottom and sides. I do still feel that both the mortar and stones have to be 'too' wet for this to work, but alas, it goes fine and afterwards they seem pretty well stuck too. Hopefully wednesday will offer good weather and I'll be able to put in the 4th and 5th courses, and manage to get the last side-arch stones mortared in. Then the weekend might lead to an attempt at the arch... or at the minimum cut the back of the arch bricks to the correct shape.
                Any tips for the arch? It seems like a very challenging thing to do, especially with thin mortar joints, and the need for it to fit and look visually pleasing.
                • RandyJ
                  • May 2010
                  • 1191
                  #23
                  Toiletman I don't know if you want to hear it or not but when I did my arches I went with pretty wet mortar. That way it was easier to get the tight joints. Besides you have the form to hold it in place. Once everything has set then you pull the form and clean up.
                  Randy
                  • Toiletman
                    • Sep 2023
                    • 105
                    #24
                    Randy
                    You're still going much faster RandyJ but I've finally taken your advice and got the inner arch in today. Went together much better than I expected. How long did you wait to pull the form? I'm assuming at least a day?
                    For the rest progress has been pretty OK, although as mentioned: slow. Row 5 is in, 6 is halfway and row 7 is cut. I hope that's going to be the first one to cover the arch fully.
                    I've shared pictures below, some general questions:
                    • I've been using some old towels/sheets to keep the dome moist, and also to specifically wet stones just before mortaring in new ones. This seems to be working pretty ok, especially as adding water directly to the stones just doesn't work anymore on the higher slopes. Is this a common experience? Any other way's of working to consider?
                    • These higher slopes are starting to need stick to support them. It's rather fiddly work and I don't really have the hang of it yet. My sticks are kind of big compared to what I see around here, and they're quite loose... typically with cleaning the excess mortar I tap a few of them over from bumping into them. Is this a common experience? Or do you guys tap them into place or something?
                    Thanks again for all the advice and inspiration that you guys are providing, it's really fun to see it coming together more and more, and get first hands experience on the stuff that other people have already ran into.
                    • RandyJ
                      • May 2010
                      • 1191
                      #25
                      Hey Toiletman the dome arch I was not very worried about it falling so I think I mat have only waited 45 minutes to maybe 1.5 hrs. It was not very long at all. I was worried I had a bunch of mortar to clean up so once it was solid enough that it was no longer squishier I pulled the form and cleaned up. I had to pound my key stone into place with a deadblow mallet so I knew everything was tight so just made sure nothing was wiggle and went for it. The front arch I waited a bit longer but a big part of that was waiting for a friend to get there to help me lift the vent into place . I had just done the vent arch and then vent like 2hr later so was probably 3 to 4 hours after I had set the arch in place I pulled the form. It was also a tight fit so I was not worried about it moving. I was more worried I would hit it trying to lift the vent into place and knock something loose. This was my experience your mileage may very. I would say do what is comfortable for you. But is should hold just fine in a few hours. The dome braces the walls for you.
                      Randy
                      • Toiletman
                        • Sep 2023
                        • 105
                        #26
                        Randy
                        Wow, that's pretty quick. I had to gently tap my keystone in place, so I didn't want to risk it. However, I pulled it out today, and indeed quite a bit of mortar leakage. However, one day later it was still easily cleanable so it turned out quite nice. The side supports are a lot worse, I've probably gotta clean them with a power tool... or try to sand them or sth... any tips on cleaning dried up mortar?
                        • Toiletman
                          • Sep 2023
                          • 105
                          #27
                          Another small update: I got the first 'full round' layer in... it's also the penultimate halfbrick layer. One more to go, which is already cut so hopefully I can put it in tomorrow. After weeks of rain, flooding and cold, now we have a heatwave.. so probably working in very small batches and getting things very wet again. After that it's time to modify the IT to fit the small bricks and see how that goes.
                          After the large tolerances on the firebricks I was worried about the build going out of whack. Luckily the laser proved that it's worked itself out correctly. there's max 5mm / 1/8" difference in the extremes.
                            • 5260
                            #28
                            Nice use of laser level. It is common to see the dreaded droop after clearing the inner arch with your dome courses. Looks like you are right on par.
                            • Toiletman
                              • Sep 2023
                              • 105
                              #29
                              Thanks for your comment UtahBeehiver !
                              Latest status update: The halfbrick courses are all in and I've been hard at work cutting the quarter bricks. In doing that I've run into a little issue. Actually I'm not sure if it's really a problem, but I'd at least like to share it such that other people don't make the same mistake.
                              As probably everyone has, I've been using the great calculation sheet by deejayoh. While cutting the bricks I assumed that I had to spread the cuts equally across the full brick. However, that's not really the case: the sheet by default calculates the longest side of the cut brick to be a half or quarterbrick size. As a cutting jig I'm using Chipster's design, flipping the brick after each cut. This results in a long and a short side sharing the full length of the brick --> instead of 'two long sides' as the calculator assumes by default.
                              This difference is quite small at small angles (lower in the dome), but gets larger and larger the higher up you come. For the half bricks it did not cause any realizable problems, but when cutting the final quarter brick course I was struggling to get the spacing correct, hence I dove in. It now seems that the bricks for course 10 I cut are basically 5mm / 1/8" too long. I've still got to put course 9 in, so I haven't been able to test yet to see if it would really bother me. In the end it would result in more mortar usage, which shouldn't really be a problem. Luckily course 11 hasn't been cut yet, so for that one I can correct.
                              Lessons learned:
                              • Check the calculator thread more carefully, deejayoh mentions the possibility to adjust the brick width there
                              • 'Quarter bricks' are really only 'quarter bricks' for course 9, afterwards they become smaller.
                              Find below some pictures of the current status and also illustration of how course 10 and 11 bricks fit inside a full brick.
                              Did you guys run into the same issue? Or did you correct for it beforehand in the calculator? I might've just missed this in other posts as the focus while looking through these threads was on understanding the generic concept and creating the cutting jig.
                              • rsandler
                                • Apr 2012
                                • 363
                                #30
                                Wire brush and white vinegar worked pretty well for me to clean up excess mortar; for bigger squeezed out bits, just aggressively scraping with a trowel can often do the trick.
