Questions about landing area
  • Zimmy
    • Oct 2023
    • 29
    I'm laying out the floor of my 42" oven build and have some questions:
    1. How important is the landing area depth dimension (not thickness)? The Pompeii plans call for an 8" vent landing and a 12" oven landing depth. I am a bit constrained on oven depth in my corner build due to where I poured the 4" thick x 42" diameter area of vermicucrete. I can get maybe 7-8 inches of oven landing before I am at the edge of the slab. I see some build photos on here that seem to have almost no landing, although they do appear abrupt/truncated. My L-shaped setup has a prep counter on one side and a bar on the other to place items coming out of the oven, so if it is just for a convenient resting spot I am fine to lose a bit of that feature to the front.
    2. More about landing geometry: I see several folks have made a T-shaped landing with their floor where the vent landing is narrower than the oven landing, presumably to create the reveal that allows an inner door seal. I plan to build a brick dome arch a la Mongo's 42" build thread so I think that means the narrow part of the T is one brick length (9") deep and then widening a bit for the decorative external arch. Does this butt up against the dome arch, or is the flue opening a third arch? A top-down view of the footprint of these features would be really helpful.
    3. What, if any, clearance is needed between the floor bricks (trimmed to 42" diameter circle) and the dome bricks? I plan to just butt them up against each other while laying the first course.
    4. I hear some clearance between the dome arch and the decorative arch is good to accommodate thermal expansion. What kind of gap are we talking 1/8", 1/2"? Does that gap then get covered with the exterior finish?
    I'll try to get a build progress post up here soon.
  • JRPizza
    • Jan 2012
    • 1558
    Hey Zimmy, I also did a corner build so you might want to take a look at my build thread. I learned, like you are, that fitting an oven into a corner is more difficult than it looks!
    I am somewhat confused by the terms vent landing and oven landing, as many ovens, including mine, have the oven set so the vent landing is close to flush with the front of the slab and there is no additional landing. I missed being flush by the width of one brick thinking I might add a decorative layer to my arch, but decided I didn't need one. I guess you could extend the area if front of the oven increasing the length of the landing, but too much makes it harder to maintain your fire and cook your food.
    Your minimum landing (vent) will be determined by what kind of vent you build. A common length for brick vents is 1.5 bricks, which gives you a good structure and plenty of room to transition to your chimney. Some folks use a cast or pre-fabbed metal vent that allows for a more shallow landing. You need to plan out what your chimney will look like and how you want to attach it before you know exactly what your landing length will be.
    My build thread
    • JRPizza
      • Jan 2012
      • 1558
      Regarding your second question, my "landing" does have two widths - there is the initial width that sits under the inner arch, where the inner arch controls the oven opening width, and a wider longer vent floor that sits under the chimney and exposes an inch or so of the inner arch for my door to seat against (the reveal). In my last post I said the vent landing is a function of the construction type and design of the vent, but there is also a few inches you can play with depending on how fore/aft your inner arch sits in relation to the oven dome. Have a look at my build and see if any of this makes sense.
      My build thread
      • Zimmy
        • Oct 2023
        • 29
        Appreciate the response JR. That makes perfect sense. Since I do seem to be more constrained on depth than I expected, I plan to have part of the cutout for the vent in the dome arch and the bulk in the slightly larger vent arch so I can get away with one course of 9" firebricks for each and then I might be able to squeeze in a shallow arch of decorative bricks in front of that to protect the fire bricks and to have a reveal for the blankets/stucco to butt against. Slightly reducing the diameter from 42" to 40" is in play as well. One thing that is giving me pause is having the vent span the dome arch to the vent arch mechanically couples them, which seems to be the opposite of what folks are doing to isolate them both thermally and mechanically. Maybe slotted holes in the DuraVent plate with Belville washers will allow some movement.
        • JRPizza
          • Jan 2012
          • 1558
          There are a few tricks to shorten the vent. Some folks straddle the inner arch like in this picture, and I think UtahBeehiver might have done it but I can't find any of his build pics right now. I made some L shaped bricks to go up and over the inner arch, giving me a shorter landing while allowing for a heat break.
          My build thread
          • Zimmy
            • Oct 2023
            • 29
            I saw the 1 inch overlap you did between the dome arch and the vent arch with the RTV-bonded braided ceramic rope seals. That will buy me another inch. For the bolts mounting the flange to the triangular bricks over the arch, do those get a nut in a counter-bored hole in the bottom of the brick, or some kind of insert/anchor? If the brick was fully supported on all sides by other mortared bricks, I would be ok with the outward expansion forces of an expanding insert but these will be near an edge so a nut or bonded insert could better prevent edge blowout.
            I bit the bullet and reduced my oven diameter all the way down to 37.5" That allows me a full 5" on each back side of the dome for insulation, vermicucrete, and stucco. It also allows me to switch to a 6" vent, which only has a 10x10 flange instead of the 12x12 on the 8" vent. Now I have enough room to flare the arch openings a bit and have room for a decorative arch. It really can't be overemphasized how important it is to understand how the arches work before getting started. My corner build top slab could have been done much more efficiently if I understood how much deeper the oven is than wide. A simple chamfer on the front corner instead of the curve I made would have got me more area for the arch ends. Oh well, I started off thinking I was only going to build a 36" oven anyway then got fascinated with the 42" once I saw how huge my slab was going to be.
            • JRPizza
              • Jan 2012
              • 1558
              I didn't use inserts, as I also had concerns about expansion. I used a through bolt design, with just a straight hole through the brick, and the head of the bolt sitting in the mortar line. I slit the end of the bolt so I could use a straight bladed screwdriver to keep the bolt from rotating when I tightened the nut. I was an aerospace fastener guy back in the day so enjoy using some of the tricks I learned along the way.
              My build thread
              • Zimmy
                • Oct 2023
                • 29
                Poor man's Hi-Lok for the win!
                • JRPizza
                  • Jan 2012
                  • 1558
                  Wow, someone else that knows what a Hi-Lok is! Were you in the business?
                  My build thread
                  • Zimmy
                    • Oct 2023
                    • 29
                    27 years in aerospace so far. Hoping to squeeze a few more out of it before retirement. I find that many of my hobbies seem to attract engineers, or at least those with an engineering mindset. I've met many folks who majored in liberal arts that would have made excellent engineers.
                    • JRPizza
                      • Jan 2012
                      • 1558
                      I put in 36 years, most of it for Boeing and the last bunch for whatever we became when MD bought us with our own money.
                      Yes there a lots of engineers here, and quite a few tradesmen (tradespeople?) that would have made damn good engineers if they wanted to go that way too!
                      My build thread
                      • mongota
                        • Jun 2011
                        • 428
                        I have about 21000 hours flying Boeings. Thank you for your service! lol
                        Mongo
                        • mongota
                          • Jun 2011
                          • 428
                          It can indeed be tricky. Drawings helped me understand that once I added in the additional thicknesses of the insulation, the stucco shell, and stone veneer on the exterior of my dome that I'd be short in space in the front after building the front vent tunnel. To get a bit more space in front, I planned my oven with an additional cantilevered countertop surface in front of the landing arch. It's not much, but it's enough to finish the front. Too deep and while the "additional working space" might have been nice, it could have made reaching into the deeper recess of the oven a bit more difficult. Working a pizza peel is easy. But when moving around heavier pots or a tuscan grill inside the oven, getting in close can make it easier.
                          Mongo
