  • IH123
    today's progress:installed more of the work-form, still need to fill gaps, secure work-form for slab load , and test rigidity.
    If you are still planning on pouring your own vermicrete slab, be aware that because of the hygroscopic nature of the grains there is far more water required in the mix that needs to be removed. Check my experiment on drying a vermicrete slab, attached. Using calcium silicate board, although far more expensive, has the advantage of already being dry, so there's far less problem about removing underfloor moisture. The underfloor weep holes in the supporting slab greatly assist in this water removal, particularly for the initial drying fires after the build is complete.
    Vermicrete insulating slab PDF.pdf
    You will also need the vermicrete table. As the table shows a higher proportion of cement provides strength but reduces insulation value. So, use a 5:1 mix for underfloor to provide sufficient strength for the floor bricks and oven. You can go far leaner for over the dome insulation (I use 10:1 over the blanket layers), but if you are still doing the enclosure style just using loose perlite or vermiculite is a better cheaper and simpler insulation solution than a blanket and vermiculite combination.
    No don’t cut them in half first. You will waste cutting time, blades and create double the amount of offcuts. As each chain rises so the angle becomes greater. If you can’t use a jig just mark out the brick with a template and cut to the marked line without a jig. It’s not hard.
  • IH123
    This method of cutting the bricks (depending on their actual size) may be helpful in reducing the number of cuts (3 cuts gives you two bricks), with minimal wastage. The wedges can also be used to fill gaps from the outside.
    Click image for larger version Name:	IMG_2306.jpg Views:	0 Size:	27.7 KB ID:	471165
    Thanks, I've seen this on the forums and might use it. however, it could cost another wood jig for the wet saw to cut it, I might just cut half all of them and then make jigs for each course (I might need 2-4 jigs per each course however I would once finish fully a course re-use the same jigs and make the angle cut less). my wet saw has nothing to mitre except the 90 degree tray and I will be making the custom mitre jigs . I chose to have the entire dome be derived from same cut (taper and wedge) however as courses go up there is another two cuts on it to fit it in the sphere ( so not really all jigs need to be constantly changed per course)
  • IH123
    Today's progress: completed the centre work-form (the one that will never be removed after pouring the slab), and partially the first perimeter work-form. next is the outer most perimeter work-form.
    Originally posted by IH123 View Post
    Thank you, my design diagrams fell short of the actual. I saw many videos and have idea of the shape. I will try to keep the block near the inner arch a full brick. as for the mortar gap, each time I cut the width will be less than an exact half because of the blade thickness. moreover, I plan to cut larger and trim later as cutting shorter is irreversible.
  • IH123
    Why don't you set up a thread in "Pompeii Oven Construction" and I will move all the posts to that thread. This topic/area is the one that gets the most activity and views.
    I did: https://community.fornobravo.com/for...eii-neapolitan
    Thanks for taking care of the moving
  • IH123
    As David mentioned, we do not see builder normally plan and research there build like this, so kudos to you. A couple comments. Both the inner and outer arch dimensions don't seem to account for the mortar gap so dimensions may need to be adjusted. On the inner arch, consider a taper inner arch to make to dome to inner arch interface more seamless. Takes work to do this arch but pays off on the back end when mating the dome to the arch. With a tapered inner arch you need to start with a full length brick so 4.5 length bricks will not work. There are many examples out there. JR Pizza did a good job on this. Here is an example of a tapered inner arch from my build. [ATTACH]n471130[/ATTACH] Click image for larger version  Name:	41B Course 5 7.4.12.jpg Views:	0 Size:	540.0 KB ID:	471131
    Also, you can attached up to five pics on a post if you keep the pics below 1.25 meg (know this is small by todays standard) .
  • IH123
    Because moisture always travels away from the heat source and gravity also assists in it accumulating under the floor bricks, the insulation layer, which is highly hygroscopic (unless you choose foam glass), the underfloor insulation layer has the ability to hold a very large amount of moisture (check the volume of your proposed underfloor insulation. Unless trapped moisture is given a pathway exit, complete drying can take months. Remember that one litre of water creates more than 1500 litres of steam. So in addition for this steam to escape the holes also act as pressure relief. The large amount of water added during the build needs to be teased out slowly. In addition, if weather is allowed entry to a dry oven it also accumulates in both the dome and underfloor insulation layers. Depending on climate, apart from rain, humidity also accumulates in the whole oven, even if covered by a roof. This alone can impact the oven’s performance and often a long slow fire the day before a decent cook up is a good idea if the oven has been idle for some time.
    so under a linear force like gravity or increasing force like heat pressure from dome, the moisture will be pushed downward from hearth->insulation-> perlte-cement->concrete slab, however the water is going to likely be moved over the entire oven footprint and even radiating outwards on the concrete slab; creating a weeping holes in the slab will accelerate the penetration in a 5.5" thick slab however that only applies for the following: direct area under the holes and on top surface (which is relatively going to be very small compared to oven foot print), and, as moisture reduces near the holes then more will be absorbed towards it creating like a micro stream to the holes; however, there is still the heat and gravity and I am not sure how much faster a tiny hole with small surface area will shed. my original plan for this is was: as the water reaches the top of the concrete slab, it could escape outwards if there is any type of moisture barrier (like aluminum foil or vapour barrier on slab) and seep sideways all over the insulation edges. if you see my perlite-cement insulation diagram, I would have to leave the entire edges of the insulation (side edges) fully exposed so moisture can leak through outwards. it might be a larger area than few holes. I am sure having many tiny holes on the slab will help however on the expense of the rigidity and structural strength of the slab. moreover, most of my oven foot print (dome walls and hearth) are over cmu cores that are fully grouted so any moisture will travel into those grouted cores and saturate them downwards to the bottom slab, very little is left for streams to flow into holes.I am thinking if I could just not create any holes on the concrete slab, the perlie-cement layer is a sponge and would seep any liquid moisture from sideways. if the sides of the oven (roof/siding) are water proof then no water moisture would come in direct contact. what do you think?​
    As David mentioned, we do not see builder normally plan and research there build like this, so kudos to you. A couple comments. Both the inner and outer arch dimensions don't seem to account for the mortar gap so dimensions may need to be adjusted. On the inner arch, consider a taper inner arch to make to dome to inner arch interface more seamless. Takes work to do this arch but pays off on the back end when mating the dome to the arch. With a tapered inner arch you need to start with a full length brick so 4.5 length bricks will not work. There are many examples out there. JR Pizza did a good job on this. Here is an example of a tapered inner arch from my build. Taper Arch Example.pdf Click image for larger version
  • IH123
    Excellent plans, you've obviously researched and thought out this build really well.
    A couple of things:
    It looks like you have no access to the centre of your stand and if so you won't be able to remove any props supporting the supporting slab pour. I guess this doesn't really matter, they could stay there forever. Do consider either casting weep holes through the supporting slab or drilling them later. Casting them is probably easier because there's no problem in dodging hitting steel if drilling. An enclosure design is better than an igloo in terms of keeping out moisture, but all ovens suffer from moisture accumulation under the floor, particularly in the building stage and the weep holes do a great job of providing an exit for that moisture.
    It looks like you are planning to make precise cuts of the floor bricks and building the dome around the outside of the floor. If this is correct try to get medium duty firebricks because high duty ones are far tougher to cut and you'll go through expensive diamond blades a lot quicker. Because you'll do a lot of cutting and the build will take some time the hiring of a brick saw will get expensive, far better to buy one and resell after the project if you want to recoup costs.
    1- why do I need weep holes on slab? I am creating vents in the cmu walls not on the slab, they are positioned at 90 degrees angle so regardless which direction any wind is flowing it will push from one side and vent in another any trapped moisture and pressure in those closed cubes.
    2-I have bricks that are rated for about 2500F - not heavy duty, 9"x4.5"x2.625" each weighs abut 3.3kg. I have a 10" wetsaw (will require two passes on some cuts). I have all tools I bought used at steep prices. I have concrete vibrator, cement drum mixer, paddle mixer, wet saw, mitre saw, concrete saw... etc
    3- for moisture enclosure, I am actually going a totally new plan, bought two Aluminum sheets 24 gauge 0.020" each is 4ftx8ft , I will use a shingle style shell with 1" gap between the aluminum sheet and oven outer layer made by metal clips anchored to the perlite-cement layer: imagine it like an orange peel or earth equator lines,at bottom will be a big circular warp lets say about 6"-8" high, then next I put another wrap above it overlapping with it and so on, when I reach the peak pole of the dome, I will create a hole in the sheet and on top of it I will create a big umbrella so any rainfalls or melts will fall far over the shingles. same for archway however rectangular. the sheets will cover the entire slab top not just the dome so one wrap will cover the slab and has a small cantilever and drop control so basically a manta ray shape cover separated from oven by a 1" gap , is that crazy? my backup plan is to use the sheets as a roof top metal sheets if I ended up with lumber roof
    A couple of things:
  • IH123
ID:	471106Today work: clean the cmu block cores from all debris, wash dust and suck water with wet dry shop vac. I had beam rebars between each course, I placed the 4th course beam rebars (10mm) will be removed while grouting and put back before top slab pour, this is to allow for concrete vibrator access as they are pretty jamming at top
