Re: Aussie Mobile base oven
Hi,
Is your oven designed to fit on a trailer or do you just want to wheel it around your yard to cook in a different spot each week ?
Re: Aussie Mobile base oven finished
Hi all thanks to you all my oven is finally finished,sorry i had no picks of the expansion joint i fitted between the dome and the chimney mount as the camera
was dead at the time.anyhow after i finished the expansion joint i coated
the dome with 3 coats of flexible pond liner from Bondall,i then painted the
whole oven with dulux paint on render.Im currantly getting a carport come pergola fitted so the oven will have proper home once fitted i will post the pic's
cheers and thanks
Peter3 Photos
Hi all fired the oven sunday night 1hr up to temp let settle cooked up beer can chicken
door worked a treat exellent draft it was sooted up after a hour but you could still see through it,best part you can check the fire at a glance as i was doing some chores around the garden.
Cheers Peter
Wow! Very cool door! May I ask if you have to clean it much?
Travis
Nice looking door. What did you use to get the silver color on the frame?
Hi all ive made up a door i plaigerised on from this site
$120.00 au for the 5mm glass
cheers Peter1 Photo
Yeah the towing is a pain. Especially when you forget you're towing it and you hit a speed bump !
yeah I think towing would be an issue for me
G"day Damon the only thing i would do to make the bricks more stable for a mobile towable oven i would run metal straps over the dome attatched to allthread rod passing through the base and fasten the dome down then cover with ceramic blanket.
just make sure your trailer has soft springs and shockers fitted,sounds like a project amagine the cost to tow the bugger!!!!
cheers Peter
Peter quite an interesting oven, I like the portable aspect. I was camping on the October long weekend at an out of town caravan park, with a group of friends. One bought his home BBQ and cooked a whole range of stuff on it, even stir fry. Then another bought his spit along......as I was watching it all over a few beers they joked at me saying wheres is my brick oven.....now all I need to do is work out how I could build one like yours and tow it along with me.....inspiring
Thanks mate here are are the photos of the last pizza party.
good luck with your project as u can see i used no special
materials and 5 firings later only some small cracks coming from my flue mount area.You can buy a good book from Earth Garden - sustainable living with country and city alternatives i think
is the web site the book is on building brick ovens in aus!only $20.00,they are in Trentham not far from you.On sunday fired up for 1.5 hours inside temp 414deg i let the fire burn right down then put in 1 lkg lamb 1kg beef spuds pumkin a mix of pepers caps and eggplant 2 hours approx later + beer the best bloody roast we have ever had mate,not to mention if you follow the forno wood fired pizza book you will eat the best pizza u have ever had.good luck with your project mate any probs message me cheers
Peter3 Photos
Hi Peter,
I'm new to the site , but really enjoyed reading through your building posts. Thanx for going to the time and effort to record your journey. Love your oven, well done mate !
Cheere Lee
G"day all got the base finished cement sheet rendered wth dulux acrylic render great stuff .pizza party sunday arvo should be great.
cheers peter2 Photos
G"day all its been a long day have spent 14hrs curing the oven.
slowly ramped up the temp through the day,only had a small crack appear
around one side of the square front buts looks not to be a problem.
Not one crack in dome yet,We made roast pork, veggies and banana pie with icecream for desert.We all think its the best roast we have had in years.
Cheers Peter4 PhotosLast edited by toyota08; 09-27-2008, 03:01 AM.
