BA's Dome! Let the games Begin!
  • #76
    I'm curious how you are handling the cage (screen enclosure), as well. The location you have chosen is similar to where my first choice was, but dealing with the cage and the fact I would probably not have room for a door, led me just outside the encosure. It sure would be nice to avoid the mosquitos...yet another oven to be jealous of.
    Very nice work so far, I love these flared entries that have become so popular since my build...damn, there is the jealousy again.
    RT
    • #77
      Originally posted by drogers View Post
      It will be interesting how you handle the screen enclosure and the chimney in the area near it.
      Interesting is just one of the words I can think of . I think the design I came up with should work out just fine. It's hard to describe but I should have the Chicago brick face done in a few weeks so I can remove all the lovely Florida critters that decided to move in.
      How cold was it in your area this morning Drogers? We have frost so it must be a frozen tundra where you are
      Bill,
      Check out my build http://www.fornobravo.com/forum/f8/b...egin-5443.html
      • #78
        Originally posted by mfiore View Post
        Your entry way and flue tile looks great! Really quite professional. I'm enjoying your build.
        Thanks Mike, I got the tip on the flue tiles from you and Les!
        So far so good. Besides a small set back with the bad mortar this has gone relatively smooth. Heck, if I had light when I got home from work I'd probably be finished.
        Thanks again,
        Bill
        Bill,
        • #79
          Originally posted by exceloven View Post
          Everything you've done looks great so far!
          Thanks Mark!
          Bill,
          • #80
            Originally posted by RTflorida View Post
            I'm curious how you are handling the cage (screen enclosure), as well. RT
            Thanks RT,
            I hung a plumb line down from my top screen beam to layout out my oven entry/arch ahead of time so it would keep the chimney outside and the brick work arch reveal inside. My idea is to simply cut a groove in the brick once set so I can run the rubber bead that holds the screen in place. I'll break out the laser for that one so I can get a perfectly even cut on all sides keeping the screen nice and flat. I'll have the Old Chicago brick covering the entire dome, chimney, and arch so it should look pretty cool.
            Stay tuned....
            Bill,
            • #81
              Bill,
              It was 34F in Inverness this morning. We had a heavy dew, but no frost, tonight probably won't be as warm.
              Don
              • #82
                I think your entry looks great. You may have a little smoke upon first firing it up, but you could always make something like Frances did- with the tin shield and twirly bit legs. When I fire mine up, I use my crude vent door- concrete backer board tilted backward and raised up about 1 inch. That keeps smoke to a minimum as well. As does well-seasoned, dry wood.
                Another benefit of the entry like yours is that it will be a lot easier to get your door in and out. I have to work at mine- you won't have to.
                Elizabeth
                • #83
                  Thanks Elizabeth
                  I was wondering if I should drop my arch a half inch on the face to help encourage the smoke up the chimney...?
                  I'm working on that design right now. I picked up my Old Chicago bricks on the way home tonight... Very cool
                  Thanks again,
                  Bill
                  Bill,
                  • #84
                    That's what I did. About 3/4 to one inch below the arch. So far so good - Please bear in mind, I also have a generous flue pipe with a reasonably long length (not that I'm bragging....). I can't believe what just got typed from my fingers.... The horror!!
                    I love the bricks - I saw them on an episode of Rock Solid. Really cool.
                    Christo
                    My oven progress -
                    sigpic
                    • #85
                      Here are my bricks that I'm going to use for the arch, chimney, and dome exterior. Heck, these are so cool, I may just cut some into 1/2" slices and use that for my stand exterior....
ID:	273001 Man, just looking at these makes me smell pizza...
ID:	273002 Close up of bricks... Trying to convince my 12 year old son why I had to pay for these was fun.
ID:	273003 The Armada is getting a good workout from the build! 200 Chicago bricks is nothing compared to what I did to it when I had to get the blocks and cement for the hearth stand.
                      I can't wait to see what this is going to look like when it's finished. AND I can even cook in it as well
                      Ha ha ha.....
                      Bill,
                      • #86
                        Christo!
                        I'm rolling over here!
                        I just saw that episode over the weekend. They use a very cool epoxy grout that just had to be broomed off. Very nice.
                        I'm wondering if I should go with over grouted mortar joints or just not tool them too much?
                        Any ideas or pictures will be appreciated! I looked up a few pictures of some of the old buildings and most have a nice finish to them.
                        Stay tuned!
                        Bill,
                        • #87
                          Looks like you really had the Ramada loaded down....
                          I bet it was fun to drive home!
                          Christo
                          My oven progress -
                          sigpic
                          • #88
                            Ditto - I went 3/4 inch, seems to help.
                            Les...
                            • #89
                              ...very glad to hear your dimensions are working so well for you, Christo.
                              My outer arch is a bit higher than the inner one, because I didn't want to bump my head on it all the time... turns out that wasn't such a good idea - I wish I'd read this thread beforehand.
                              I love the bricks btw!
                              • #90
                                [QUOTE=Frances;45306 My outer arch is a bit higher than the inner one, because I didn't want to bump my head on it all the time... turns out that wasn't such a good idea - I wish I'd read this thread beforehand.
                                I love the bricks btw![/QUOTE]
                                Thanks Frances,
                                I want to cover up the exposed edge of the fire brick as much as possible so dropping the arch would enhance the function along with the aesthetics.
                                I'm trying to decide what to do with the brick. There are so many designs I could drive myself nuts (if I wasn't there already). I have two basic designs for the foundations. The arch will be the same but one would incorporate full brick, the other would be halves.
Name:	Chicago Brick Entry Ideas 016.jpg
ID:	273010 Full brick design. This would give it a more massive look making the front reveal larger along with allowing me to use full brick for the arch as shown below. The drawback would be that it would make it farther to get inside the oven which may or may not be an issue.
Name:	Chicago Brick Entry Ideas 017.jpg
ID:	273011 This design allows me to use half brick on the arch giving me a better view in the oven. The only drawback I can see would be that it gives me less brick to work with when tying my screen into the mix. That is not a big deal; having the best reveal is a bit more important to me.
Name:	Chicago Brick Entry Ideas 018.jpg
ID:	273012 Although hard to imagine, this is how the arch would look from the bottom. I kind of like it. It looks very heavy, almost structural. Well I guess it is in a way.
                                I was fortunate enough to travel on business to Verona Italy a few years back. While I was there I took a lot of pictures of their buildings, arches, and I'm still amazed at how many arch designs were incorporated in just one single building.
                                Take a look at this.
ID:	273013 This is the home where Juliet stood on the balcony... Although not real, this 13th century structure is. I went there 4 times just to look at the stone and brick work. I was also fortunate enough to be invited to a private event held by Antolini Luigi that was held at Castlevecchio, way cool. Apparently it was the first event ever to be allowed in the castle as half is a museum, the other is occupied by the military.
ID:	273014 This is the lower level of a restaurant I dined at, It was a Roman strategic planning room back in the day. It's about 35' below the surface. Absolutely breath taking. What a night!
                                Thoughts, ideas?
                                Bill,
