i am on the home stretch with my oven - brickwork is done, dome is insulated, and all framing is done (walls and roof). i used metal studs for all of the framing. i will make the walls out of cement board, and cover them in stucco. my question is about the roof - i have been trying to avoid combustible materials at all cost, but i am at loss for the roof - if i use cement board, there will be nothing to nail shingles into. my local lumber yard sells some type of fire-retardant plywood (i guess treated with some chemical), so i was thinking of using that, then tradition roof construction - tar paper, shingles.
i am sure the concern unnecessary - i have 2-4" of insulating blanket, and intend to fill the remainder of the chamber with vermiculite, but it is worth a slight consideration just to be safe.
any ideas for this? thanks!
