Vermiculite ?
  • bturton
    • Oct 2008
    • 35
    Vermiculite ?
    I was getting ready to order the vermiculite and noticed two different grades.
    For 4 cubic feet, the grade 2 is finer and weighs 26 pounds. 4 cubic feet of grade 4 is coarser and weighs 19 pounds. Is the weight an issue if your oven up to par otherwise? Is denser insulation more efficient?
    Bonita
    Bonita
  • christo
    • Feb 2006
    • 913
    Re: Vermiculite ?
    I would go with the lighter Vermiculte.
    Less dense is better. At the end of the day, it's the air inside the vermiculte that provides the insulation - the hard material just keeps the air from moving.
    Sounds like you're at a great stage if you are already buying vermiculte.
    Christo
    My oven progress -
    sigpic
    • bturton
      • Oct 2008
      • 35
      Re: Vermiculite ?
      Thanks,
      My slave labor will be home from college over Thanksgiving and I want to make sure I've laid in supplies. Appreciate your help!
      Bonita
