Formed up and ready to pour *pic*
  • Ellie
    • Dec 2008
    • 94
    I guess once the pad is put in I will start a thread and title it Ellie's Oven like you guys do and post pictures along the way for those who are interested. The mason is going to follow the plans from this site.
    Here it is so you can see where it is in relation to the patio.
    Ellie
  • Dino_Pizza
    • Feb 2008
    • 1036
    Re: Formed up and ready to pour *pic*
    Looks really nice Ellie, I see the wings on the side of the oven pad. I like the ovens set with an open view beyond it. Us city dwellers (like me) have them a little more cramped but still functional. You'll be really excited when you see the block walls going up on the pad it starts to take shape.
    Good Luck, Dino
    My Oven Costs Spreadsheet
    My Oven Thread
    • Ellie
      • Dec 2008
      • 94
      Thanks, Dino. The left side will be for a charcoal/wood grill and the right, simply a counter to hold stuff, plus it would look funny not having two sides, lol.
      I do dutch oven cooking so the grill will slide out and I can put the oven right on the coals on the fire brick. I am trying to figure out now how far from the coals the grill should be. Anyone know?
      This is going to be fun, fun, fun.
      Ellie
      • Jed
        • Apr 2008
        • 428
        Hi Ellie,
        You two are off and running with this new WFO project. Your location looks great. Keep the pictures coming!
        JED
        • Modthyrth
          • Mar 2008
          • 359
          My foundation was done the same way. I'm only 5'4", did a standard stand design four courses high, made my hearth slab a bit thicker than required, and the height of the oven is great. It could even be a bit higher and be fine for me, in fact. I think you'll be just fine!
          Nikki
          • Ellie
            • Dec 2008
            • 94
            That sounds great, Nikki. Thanks so much for putting my mind at ease. The folks on this forum are really nice and kind and helpful. I saw your wfo and it is beautiful.
            I am 5'6 and my daughter who will use it is 5' even. Guess she did not get my genes!!
            We are putting the hearth at 40-42 inches. Not counting the slab.
            Thanks again,
            Ellie
            • nissanneill
              • Apr 2007
              • 1886
              Hi Ellie,
              I would get a border foundation dug a little deeper so as to accommodate a little more reinforcing steel. The whole thing will weigh almost a ton and needs to be on good solid earth and appropriate foundations. I feel that it is always better to slightly over engineer the footings than have them move and break down in time.
              Also to remove the timber that is separating the slab into 3 separate areas (or simply slide the timbers back. The reinforcing rods can then run and be tied straight through to each other and topped with steel mesh.
              You location is great as it allows you to extend your existing roof or maybe a timber pergola vine covered to generate the cooling atmosphere on your hot sultry times when you want to use your oven.
              Keep up the pics and go for it kid!!!
              Cheers.
              Neill’s Pompeiii #1
              Neill’s kitchen underway
              • Frances
                • Aug 2007
                • 2186
                If you want to read more about user to oven hight ratio, maybe you could check out this thread:
                http://www.fornobravo.com/forum/f7/h...ence-3363.html
                My oven's actually higher than average and I'm quite small and it works out fine, so I'm sure you'll be good.
                • Ellie
                  • Dec 2008
                  • 94
                  Thanks Frances. I appreciate it.
                  Ellie
