Where to buy perlite?
  • HelotesJoe
    • Feb 2009
    • 3
    Greetings!
    I am getting ready to start building... I've stopped by Lowe's and Home Depot asking about perlite and they don't sell it in the bulk I need. Where should I be looking?
    Thanks,
    Joe
  • jon bell
    • May 2008
    • 12
    Re: Where to buy perlite?
    Hi Joe,
    I found mine at a local nursery in 3.5 cu ft bags at around $23 per bag. I found same size bag at building supply for $9 per bag but it was like a powder instead of like pellets. i used the combo in my mix.
      Swimming pool suppliers have it too.
      • wlively
        • May 2005
        • 384
        If you are looking for loose fill, I bought Harborlite Perlite in 4 cu/ft bags for $10 in south Austin, but it is very fine.
        If you are wanting for Perlcrete mix, then I bought 4 cu/ft bags of vermiculite at a nursery on Thousand Oaks in N. San Antonio.
        Every pool supply store I went to just gave me blank empty stares.
        PS: If you go the HeatStop route there is a very cheap supplier just south of San Antonio.
        Wade Lively
        • Jed
          • Apr 2008
          • 428
          I bought my perlite from a masonry supply business where it is commonly used to insulate fireplaces and such.
          JED
          • JoeT62
            • May 2007
            • 185
            Masonry supply or horticulture supply.
            "You better cut the pizza in four pieces because I'm not hungry enough to eat six."
            -- Yogi Berra
            Forno Tito
            • HelotesJoe
              • Feb 2009
              • 3
              Thanks to all for your help and recommendations!
              Joe
              • Xabia Jim
                • Dec 2006
                • 1168
                I got mine from the local masonry supply company (michigan)
                • lplough
                  • Nov 2011
                  • 2
                  I bought some from Hometown perlite (website of the same name)....Though I am not sure I got the right stuff.. It was the the fine "industrial" grade, for concrete mixes, and not the loose fill...will that work to mix with refractory cement?
                  Louis
                  • Rrice
                    • Sep 2014
                    • 1
                    If I want to use vermiculite as an insulating concrete on top of my FB insulation, which type should I get? Can you tell me the name of the nursery near Thousand Oaks in SA, TX if they have the right product or where else in SA I might be able to find it? Thanks!
                    • Novaslo
                      • Dec 2013
                      • 279
                      Home Depot is where I got it.
                      • Tscarborough
                        • Oct 2009
                        • 3341
                        Masonry supply houses, wholesale gardening houses, or pool supply companies are your best bet. The box stores or retail garden centers may have it, but they will charge 5-10 times the price it is worth.
                          • 5260
                          Like Tscar says, just go to a masonry or block supplier, perlite is used to fill cores of CMUs.
                          • stevef22
                            • Mar 2020
                            • 131
                            Hi, I live in San Antonio and would like to know supplier. Please let me know.
