Re: Smuth's 36" Pompeii Oven
Scott,
I cut the angle. A shim will not solve your problem. I used them to keep my radius and thats it. To minimize the "V" is to cut your bricks thinner - that will help. When I did the math, and if I cut every brick to stay off bond - the top bricks ended up being about 3/4 inch wide - INSANE! I get the feeling you don't want to go there. Many, many have built their ovens the way you are going with great results - go for it.
Les...
Originally posted by smuth10
View Post
Les...
