SC Chris's 42" WFO build
  • Dino_Pizza
    • Feb 2008
    • 1036
    #16
    Re: SC Chris's 42" WFO build
    Hi Chris, I know you'll be happy with the 2" of Insulating Board. And your oven height will be just right too.
    RE Soldier Course Tapering:
    As you saw on my threads drawing this morning, I did NOT taper my soldiers wide side. On a 42" WFO it leaves a 9/16" gap at the outside that gets smaller across the 4.5" brick face until they touch. I think this is quite tolerable of a gap. I WAS a bit shocked though by how much of my $$$ Refmix went to fill those gaps. A smaller oven diameter would have increased the gap and I would recommend tapering. However I think this gap for a 42" is fine. And, if you did taper, that's about 40 bricks and a lot of cutting and flipping and cutting on your tile saw at a time that I'm sure you'd rather be placing your first oven ring and tackling the bigger question of "V" gaps and compound tapers!
    After my 1st few ring courses that came out surprisingly tight with little mortar, I had wished I'd tapered the soldiers too, but after doing my arches, vent and the slooowwww race to the dome keystone/plug, I'm glad I didn't spend that time. BUT, that's just me. The pics of others tapered soldiers is beautiful and I envy them. So, good luck, hope this helps, -Dino
    My Oven Costs Spreadsheet
    My Oven Thread
    • papavino
      • May 2009
      • 220
      #17
      I didn't cut the sides of my soldier course for my 36" oven. There was an awful lot of mortar used to fill the gaps. If that's a concern for you, then I'd go ahead and try it, but like Dino said, I was more interested in going vertical than minimizing the pie shape for my soldier course.
      • SCChris
        • Jun 2009
        • 1213
        #18
        Thanks Dino and Papa.. I'll give the shoulder cuts a try and see how it goes.. If I cut a few and throw in the towel on cutting the rest of the shoulders on the soldier course, it'll be with first hand knowledge. I'll know a bunch more by Sunday afternoon.
        Chris
        • SCChris
          • Jun 2009
          • 1213
          #19
          Question on the IB. I'm figuring on mixing some thin set to attach the IB to the base. I’m guessing that this is what others have done but haven’t really found any mentioning of this. If I didn't live in earthquake country I might just assume that the weight and surrounding structure would hold things together.
          Chris
          • SCChris
            • Jun 2009
            • 1213
            #20
            Today, Saturday July 25, wasn't as productive as I would have hoped, but a step forward is better than none. I've laid out the IB rough cuts on the 4 by 6 ft panel and have what I think will allow enough left over to do a door or two at 22 by 15 or so inches. I also found Dino's narrative on how to put the IB down, Fireclay and Sand. It seems that this is the norm not the exception. My oven slab is comfortably flat and level and during framing of the pour, I created a 5? ledge in front with some compound angles and color. This was a way for me to play with pouring countertops. I?m very happy with the results of this experiment although I still need to grind and polish. I, like Dino did, am chewing on what a reasonable reach is to the back of the oven. I?m 6?2? and have a good reach but is 5?6? or even 6? too long from the front of the ledge? What about my wife? Hmmm?
            Chris
            • SCChris
              • Jun 2009
              • 1213
              #21
              Sunday July 26, 2009.
              I did get the insulation board affixed to the slab with 50/50 Fireclay and Sand. I also got a preliminary layout using Dino?s built as PDF. I had to guess on the brick staggering from the rear arch brick, the ones that run into the oven and the bricks at the front of the archway. I guessed 2 inches. I went with a 20? wide opening and a 1 inch setback on both sides for the door to sit in. The 22 inches opens to 27? at the front of the arch. It all looks good now, but I may bring it in a bit. I?ll look at Dino?s 25 5/8? and think about how that affects the brick cutting and arch structure. As I mentioned in an earlier post, I picked up 200 bricks, $1.39 each, 10 cents more than the other two brands available. What I decided was these bricks were finer grain and more consistent brick to brick. I didn?t really have any idea what a 42? oven is going to take in the way of the number of bricks so I picked up 200 for a start, if I have more than I need, great, if I need to get more I hope they?re there when I figure out that I need more.
              Let the brick cutting begin!
              Chris
              • SCChris
                • Jun 2009
                • 1213
                #22
                Up.. :-)
                I wanted to trim the fronts of the soldiers to create a tighter grout line, but in the end getting this with the 10" HF wet saw would have been a challege. I also cut back on the entrance flair to 25" from the 27 or so I had sketched. I still have a bit of floor work and need to get the arch base all mortared, up to 3 levels. Number 4 will tie into the second row of the oven. 45 and 1/2 soldier bricks down.
                Chris
                • Dino_Pizza
                  • Feb 2008
                  • 1036
                  #23
                  Nice looking floor and soldiers Chris. You'll be fine with a 25" opening. I just had a 20 pizza party over the weekend and then 2 large roasting pans in it and was able to set them in and spin them around and my landing worked fine so yours will too.
                  Is that a planter wall with coping in front of your oven? Do you have to reach over it to get in your oven? I guess your counter will probably be close to that depth. Is that why you were asking about your wife reaching in the back of the oven? If someone doesn't have a long reach, they'll just use the middle & front of the oven. Or use longer tools. It's no big deal.
                  Your arch and arch wall bricks look awesome with that 1" reveal notch in it. That tie-in will make a really strong oven. Keep up the good work, dino
                  My Oven Thread
                  • SCChris
                    • Jun 2009
                    • 1213
                    #24
                    Thanks again Dino, for the encouragement!! That is a wall cap you see below and it is going to be a bit awkward with my toes. I played with a pizza peel with a 3' overall length, and found that with a 4' handle plus the paddle, I'll be comfortable and so, I hope, should my wife. I'll likely put a 3' extension on this novelty peel when I get to that "pizza point" just to verify that the commercial version is or isn't needed.
                    Chris
                    • SCChris
                      • Jun 2009
                      • 1213
                      #25
                      Slow but steady work this weekend, not all of it on the oven. I have soldiers plus 1 now and feel like the joints on this row are much better than the soldier row. I'm starting to understand the morter texture better. I have a few highs and lows but mostly the row is flatter than the top of the soldiers. I cobled up an indespensible tool out of a $1.35 caster, a 1/2 inch square rod and some aluminum. Getting the bricks cut with clean angles that facilitate the tight joints is a bit trial and error. I hope to get the next row cut before the weekend so Saturday morning is dedicated to getting it laid. Hopfully Saturday afternoon I can cut the next row and Sunday get it installed.
                      Chris
                      • SCChris
                        • Jun 2009
                        • 1213
                        #26
                        The last couple of weeks has been slow going.. Honey Do's and getting the new deck in, have taken a bit of time. My son starts school in a week and then we're back to the normal schedule. Last weekend I got a course in and split the bricks trying to be oh so careful to get a 1/4" off of one side of the split. Well I doubled up on the cut and took a ??.. Rrrrr.. I knew I was tired and it was time to hit the surf, down time.. What came out of it was the acknowledgment that I needed a tool to simplify the course brick cuts. I'm sure that someone else is using the same tool and that it's been in use continually for 10,000 years, but I needed to figure it all out and build one. I don't know if its folly, but I'll give it a go and report back. OK today I focused on getting the arch approach and support in place. The height of the arch in the dome will be 12.5, and I have about 90 degrees of dome. So of course, the corner off of the vertical is 45 degrees. I have decided to run a 5" by 20" opening that feeds a 8" diameter 36" tall chimney.
                        Chris
                        Chris
                        • Dino_Pizza
                          • Feb 2008
                          • 1036
                          #27
                          I like your solution to the arch wall, angled bricks Chris. Looks good. I see the 1st brick is a half brick with the angle cut on it facing in. Will the bricks in front of it also be orientated like that?
                          Looking Good! - Dino
                          My Oven Thread
                          • SCChris
                            • Jun 2009
                            • 1213
                            #28
                            Thanks Dino.
                            I'll push forward with the 45 degree angle on top of the entry wall to the front. In the smoke collection area I decided, what the heck, what's another cut to soften the horizontal to vertical transition.
                            No one will ever know, but I think its cleaner to soften this transition.
                            Chris
                            • SCChris
                              • Jun 2009
                              • 1213
                              #29
                              Dino, my oven uses much of the info you posted regarding your build. Many thanks for the complete nature of your thread!! And also to those who have built before and share and have shared their experiences and expertise. Without this forum, I would never started this project / adventure.
                              At the moment I?m looking forward to getting the rear arch in place and continuing then finishing the dome. That said, I?m aware that I need to get the design for the entry to chimney transition clearer.. In a prior post I had believed that the 5 by 20 area between the rear arch and the forward entry arch would be sufficient to service the smoke. At this point, I?m not convinced this would be true. In the interest of over rather than under engineering things, I?ll be widening this. Since the chiming pipe is 7? on the inside, I?ll likely use this as the depth of the gap.
                              Chris
                              • SCChris
                                • Jun 2009
                                • 1213
                                #30
                                Finally the inner arch is in!!
                                Hurah!!
                                Beer Thirty!
                                Chris
