The thread is quite old with the last post in 2014 so you may not get a response.
Pizza Bob's 42" Build
Bob - I know it's been awhile, but I'm hoping you check from time to time. There's some similarities with your enclosure and what I'm trying to design. Both have a hipped roof that is flat on top. Is your roof pitched? What is the material and is it a solid piece or pieces that are mortared? I realize your chimney comes out the top of that, but how is it surrounded?👍 1Comment
Hello cnegrelli,Bob - I know it's been awhile, but I'm hoping you check from time to time. There's some similarities with your enclosure and what I'm trying to design. Both have a hipped roof that is flat on top. Is your roof pitched? What is the material and is it a solid piece or pieces that are mortared? I realize your chimney comes out the top of that, but how is it surrounded?
It's been quite some time since I've logged in here. I would think you are beyond this part of your build? If not, let me know and I'll get a few pictures of the top of the oven.My Oven Progress: http://www.fornobravo.com/forum/f8/p...uild-7155.html
If you fail to plan, you plan to fail!Comment
Has anyone tried a larger floor bricks? I'm wondering if it's possible to remove enough bricks to insert four larger refractory sections that form a circle - obviously smaller diameter than current 42" diameter. Thoughts or suggestions?
Thanks,
BobMy Oven Progress: http://www.fornobravo.com/forum/f8/p...uild-7155.html
Here is one done by a member but you need to have access to a welder. There have been several non weld versions done by members but you have to do a search, ie look for IT1 Photo👍 1Comment
Hi there,
Just after some advice on dimensions etc. I am looking to build a brick built wood fired oven. The area that I have available is suitable for a 36" diameter oven. What I need to know is whether anyone has built an oven this size and what is the recommended internal height of the dome as I know from reading various bits on here that it shouldn't be to high or low in order to get a good temperature.
thank in advance.
RobComment
Welcome Rob! There is a lot of information available in the Resources, Learning & Support section of the Forno Bravo site (link below). Forno Bravo offers a free set of instructions (although they are somewhat dated) to get you started on your own build. A 36" diameter oven is a very common size option for builders. The opening height to interior dome height optimum is 63% but optimum does not mean it has to be exact...just something to shoot for...
https://www.fornobravo.com/tech-resources/
If you haven't looked already, please take the time to peruse the Newbie Forum & Getting Started topic areas. Most people also find the link below as very useful.
Being new to the Forno Bravo web site, we quickly realized that we wanted to build a pizza oven and access the best information available, but did not know where to look. Getting smart about building a Wood Fired Oven (WFO) would have been easier with a little tutoring. So, listed in bold below, you find a few shortcuts to
Again welcome and please direct your posts to threads for questions & answers about specific build issues rather than posting a general question on someone's build thread...no problems on this one because you're just getting started & using the forum is a learning process.
Roseburg, Oregon
Blog: http://thetravelingloafer.blogspot.com/Comment
