? on ratio of vermiculite to cement
  • ? on ratio of vermiculite to cement
    is the ratio volume or #?
    Ratio
    I use a standard ratio of six vermiculite to one Portland by volume. It's not a critical mix, but it's good to get close. Do it by shovelfuls, pails, what have you.
    Jim
      Re: ? on ratio of vermiculite to cement
      Ratios by volume!!
        I did 8:1 under the dome, probably could've done 10:1 really, definitely by volume.
        Time flies like an arrow; Fruit Flies like a banana.
        My oven (thus far): http://www.tinyurl.com/ogorirsoven
          Under the floor you need the strength. Should be around 5:1. Over the dome go as lean as you dare. I use 10:1
