I am not sure if this variation of the "indispensible tool" has been used before. I offset the second rotational axis so I could determine the oven diameter separately from the dome height. In my case the oven diameter is 42" and the dome height will be 19". With this solution I don't have to make any changes in the length of the arm with each course in order to lower the dome height.
I'm on the 7th course above the soldiers and it is working well so far.
Mark
Mark
