Colorado oven
  • MetalHead
    • Aug 2009
    • 77
    #31
    Re: Colorado oven
    OOO OOOo oo I have a question ... You created the arches seperate from the dome? Can you explain that a little better?
    Did you also use 1/3 bricks for the whole dome? Forgive me if you state that somewhere. I am still reading the thread.
    Did you cut all sides of the bricks to get that fit? How many total bricks did you use?
    What mortar did you use?
    Columbiana, Alabama WFO Build.
    http://www.fornobravo.com/forum/f3/o...bama-7837.html
    • drseward
      • Apr 2009
      • 18
      #32
      Re: Colorado oven
      Here is an image of the brick I cut for the heat break between the entry and the inner dome arch. I left a 0.25 inch edge to contact the inner arch. I didn't use any morter at this junction, so the brick just sits up against the bricks of the inner dome arch. When you look through the entry, it just looks like the dome and entry are connected, but since there is no mortar and only 0.25 inches of contact (very little actual contact even on the 0.25 in.--mostly air), there is very little heat transfer across the junction. I considered using some kind of high temperature sealer at the junction, but opted for simply relying on the insulation packed in the 0.75" space to keep any smoke from getting between the dome and entry. It worked perfectly.
      I had two thoughts behind this approach. First, I have seen examples of cracks in the dome continuing all the way throught the entry to the very outer arch. Isolating the entry this way completely eliminated that possibility. Along with this, the dome and the entry are subjected to very different thermal stresses, so it made sense to me to isolate them from one another.
      Second, I went to a lot of trouble to insulate the dome above and below, so I didn't like the idea of this thermal "weak link" where heat could easily drain off the dome to the esposed bricks of the entry.
      I can't remember what kind of thermal performance people are getting with their ovens, but I typically fire to pizza temps one evening and it is 500F in 24 hrs., 400F in 48 hrs, 300F in 72 hrs, etc. That's with a temporary wooden door that I can't put on until the oven has cooled significantly. When I get a proper door made, I expect better residual heat retention.
      I used HeatStop 50 for mortar. I started with the Italian imported mortar, but with the precision fit, compound cut approach I was after, it wouldn't work in my hands. The HeatStop worked much better for the thin joints in my build. I can't remember now the exact amount, but I think I only used a few bags of the mortar for the entire build. That being said, I'm sure what I saved buying mortar, I spent on diamond blades.
      I started with 1/3 bricks and by the time I was at the highest rows I was using 1/4 bricks. Each piece of brick had 2 compound cuts, so the faces on the inside and the outside of the dome were factory, uncut faces. The only exception to this was on the inside of the inner dome arch where there are a couple of small cut faces exposed on the inside of the oven.
      I can't remember the total brick count.
      I hope that helps. Let me know if I can explain anything better.
      Mark
      • MetalHead
        • Aug 2009
        • 77
        #33
        Re: Colorado oven
        So when you say two compound cuts you mean the sides correct? So no bevel cuts were made on the top and bottom of each brick?
        • drseward
          • Apr 2009
          • 18
          #34
          Re: Colorado oven
          Sorry. I made a compound cut on each side and also angled the top and bottom of each brick.
          Mark
          • WoodchuckDad
            • Apr 2010
            • 209
            #35
            Re: Colorado oven
            Amazing. where do I find pictures of the rest of the build?
            WCD
            My slow journey to pizza.
            http://www.fornobravo.com/forum/f21/...ing-12769.html
            • MetalHead
              • Aug 2009
              • 77
              #36
              Re: Colorado oven
              Cool. I was on this line of thinking also. What size saw did you use? 10 inch?
              • drseward
                • Apr 2009
                • 18
                #37
                Re: Colorado oven
                WCD,
                I am working on more of the kitchen around the oven now. I'll try to post some additional photos soon. I did a poor job of documenting every step photographically (unlike many on this forum).
                MH,
                I did use a 10" HF saw.
                Mark
                • michaewa
                  • Oct 2009
                  • 52
                  #38
                  Re: Colorado oven
                  Thanks for the inspiration and answers Mark. I just set my 2nd arch, and followed your approach. The arch bricks are 'L' shaped, with only about an inch at the bottom touching the inner arch.
                  I tried to grind away some of the connecting brick between the dome and the vent walls with a grinder, with limited success. I suppose that every bit of that thermal leak that is removed will help.
                  Cheers!
                  • AndrewL
                    • May 2008
                    • 32
                    #39
                    Re: Colorado oven
                    Hey,
                    Thanks for this post. I was about to post a question on creating a thermal break between the dome and vent, and all has been explained here. Great stuff.
                    What is a "luan" jig?
                    • John K
                      • Sep 2009
                      • 216
                      #40
                      Re: Colorado oven
                      Very nice Mark
                      Just came across your build and am very impressed. Looking forward to the rest of your build
                      cheers
                      John
                      __________________
                      My Oven Thread:
                      http://www.fornobravo.com/forum/f8/j...-wfo-7911.html
                      The difference between a successful person and others is not the lack of strength, nor the lack of knowledge… but rather, the lack of will power.
                      • gone1414
                        • Jan 2011
                        • 4
                        #41
                        Re: Colorado oven
                        Man I think this is one of the nicest looking domes on here!! Can you please show us what it looks like now? Thanks sooo much, I am under way and want my dome to look just like this!
                        More pic please>??????!!!!!!!
                        Thanks very much
                        G
                        • dcleon
                          • Sep 2010
                          • 1
                          #42
                          Re: Colorado oven
                          Agreed. The brickwork on the dome is amazing.
                          I'm in your neck of the woods (sort of -- South Eastern WY) and wondering whether you got your supplies locally or directly from Forno Bravo.
                          dave
                          • Pompeii Nate
                            • May 2011
                            • 219
                            #43
                            Re: Colorado oven
                            Beautiful build Mark! I hope you are enjoying your oven by this time. Thanks for the ideas on the electric heater, thermal break and other ideas I picked up just looking at your pictures.
                            Nate
                            http://www.fornobravo.com/forum/f8/p...two-21068.html
