sanding brick. Which belt to use?
  • KEmerson
    • Jan 2009
    • 204
    Hello my invaluable friends,
    I've read about grinding or sanding down the hearth brick to get to the rough bits. I would plan on using a belt sander for this but am wondering what belt to use. Is there a belt equivalent to a diamond blade for the saw or will any regular belt suffice if only because I'm just smoothing out a surface?
    Thanks all.
    'Kim
  • Les
    • Sep 2005
    • 2945
    Re: sanding brick. Which belt to use?
    Kim,
    I recall buying 40 grit. The cheapest one's I could find. I went through 3 or 4of them.
    Les...
