Re: John's 42inch Aussie WFO
Hi John I can help you with question # 1. I used firebrick, because I had enough left over, I think the pressed brick should be fine as long as they are solids,, I am att a pic for reference..
1. I am planning to build the flue with solid dry pressed bricks. Will the weight of the chimney support itself on the external and internal arch bricks? I plan on nocking down the existing landing brickwork and erect a double brick wall rather than single.
