John's 42inch Aussie WFO - Forno Bravo Forum: The Wood-Fired Oven Community
  • John's 42inch Aussie WFO
    Hi all
    I'm from Sydney Australia and came across this Web site about a year ago. Since then I have been trawling through endless posts and have finally taken the plunge and begun work on my 42inch WFO!!
    I have never laid a brick in my life so am looking forward to the challenge
    Not only am I to build the oven but also an attached barbecue/Spit (charcoal)
    Below ground preperation with approx dimensions of 5000x4000x80
    John
    __________________
    My Oven Thread:
    http://www.fornobravo.com/forum/f8/j...-wfo-7911.html
    The difference between a successful person and others is not the lack of strength, nor the lack of knowledge… but rather, the lack of will power.
    Re: John's 42inch Aussie WFO
    As I have not laid bricks before so cheated and brought in my bricklayer to build the skeletal structure of the barbecue and WFO base
    In relation to the suspended WFO slab I utilised a half brick approach on the final brick coarse that will hide any concrete from view. Internally I have utilised 2 steel lintels for support (over engineered as per everything else I do!!). Steel sheeting has been laid down and expansion foam installed to allow for concrete movement
    Photo's to come shortly!!
    John
    __________________
    My Oven Thread:
      Hey John,
      Welcome!
      It sounds like you are getting ready to start on the dome. Make sure you insulate under the dome (and above the hearth slab). You mention a suspended hearth slab, we mostly don't do that, but each build is different. Did you download the plans from the forno bravo store (they are free!).
      Drake
      My Oven Thread:
        Good luck John!
        Take Drakes advice and download the free Forno Bravo plans...having step by step instructions makes all the difference in the world.
        See ALL of my pictures here:
          Thanks guys I am realy looking forward in getting stuck in.
          Yes I downloaded the plans sometime ago and found them very handy along with everyones posts, builds CAD Drawings and so on and was one of the selling points to my wife!!.
          I think suspended slab was a bad use of terminology from my part so appologies, I do have brickwork all the way around so it will be standard construction method. I laid the hearth slab some weeks ago and am in the process of laying the Insulation Bricks.
          Insulation bricks you say ? I decided after long discusions with the Firebrick supplier (Only one in Sydney I could locate) Field Furnace Refractories that I will achieve better insulative properties using the Insulation Bricks rather than Vermiculite so decided to go down that path.
          Insulation brick (I.F.B) 230x115x75mm.
          Drake/Breven your WFO's look fantastic and if I can get mine looking half as good I will have succeded!!
          John
          __________________
          My Oven Thread:
            I have attached some of my earlier photos during the stand and hearth construction. I originally was to build a smaller oven and therefore built the stand to suite.
            My wife then decided this was going to be too small so I was forced to part demolish the stand and extend.
            John
            __________________
            My Oven Thread:
              Performed a dry run of the insulation bricks last saturday. They appear to sit nice and level.
              The fire brick supplier recomended that I set the insulation bricks that sit under the wall of the WFO and allow the rest to just sit in place. This will assist if I ever need to change any that sit under the cooking floor.
              John
              __________________
              My Oven Thread:
                Hi John, why are you using insulating firebricks on the floor? Are you going to then use normal firebricks on top of that?
                Cheers.
                  Hi, that's correct I will lay the firebricks (cooking surface) in a Herringbone pattern on top of the Insulation Bricks.
                  Do you see a problem with using the Insulation bricks rather than vermiculite base?
                  John
                  __________________
                  My Oven Thread:
                    No, they'll work better but be more expensive. Hey, if you've got the money go for it.
                    Does the kit that you referred to come with pre-cast dome pieces or firebricks. I went to their site and they point to another site that shows pre-cast pieces.
                    Thanks.
                      The AUD $1,300.00 kit comes with Firebrick but I have seen their precast ovens in their factory. I am unsure of the cost. If you give them a call they are very helpful.
                      John
                      __________________
                      My Oven Thread:
                        Hey John,
                        Welcome to the club, Lookin good so far.. Are the insulating bricks strong enough to support the dome ? I understand they can be cut with a handsaw, I am working on a home heater and was thinking about the insulating brick in the forebox.
                        Mark
                          Hi Mark
                          The supplier actually recommended the bricks over the Vermiculite (probably as they make more $). I did ask the same question about strength to which he advised that as long as I mortared down the Insulation bricks that sit under the Walls of the oven I will not have any issues.
                          I have seen 20 odd ovens built by them/their customers (photos) that used bricks over vermiculite so can only assume that they are strong enough. I guess I will find out shortly!!!
                          I am unsure if your can cut these with a hand saw but can confirm that they are very light items.
                          How heavy will your fire box be? Will the load not be distributed across the Insulation evenly?
                          John
                          __________________
                          My Oven Thread:
                            i just wanted to be see if the insulating fire brick could take direct flame ? I will Probaby put them behind the firebrick, better off i think.....
                              Not sure about direct heat but I would be more than happy to send an email to the supplier and ask if you like?
                              Otherwise as you said place the insulation bricks behind the Firebricks.
                              John
                              __________________
                              My Oven Thread:
