Firebrick Primer
This is a sticky topic.
  • Firebrick Primer
    We have a primer on firebricks in the Pompeii Oven plans. You can find it here:
    http://fornobravo.com/pompeii_oven/brick_primer.html
    Pizza Ovens
    Outdoor Fireplaces
    Firebrick # 1 arch
    Do you see an advantage to using arched brick rather than straight. Although they cost more it seems that a more even mortar joint would be an advantage. These all appear to be medium duty or superduty firebrick where as your recomendations are for low duty. What are the disadvantages of a higher specified brick other than wood cost I have an unlimited source for free apple wood
      Re: Firebrick Primer
      Thanks James Point taken, I will use low duty, should I persue the arched brick idea?
        Balty,
        The arched brick idea is a good one... getting a nice tight mortar joint in your arch promotes strength and looks really nice. However, I'm not sure spending the extra beans on a special type of brick is the answer though... Arch sizes will vary, so the cut of the brick is dependant on the arch rise and the length of the span...
        Here's my suggestion.. go down to Home Depot to the tool section where they have the miter saws, blades, etc... somewhere in there, you'll find a tool called the Angleizer.. it includes a little software program to calculate your cuts and a reusable template thats kind of like 4 adjustable rules all screwed together... it's all pretty self explanatory once you get it, but essentially all you do is plug in your span and rise and it will spit out your dimensions, which you use your template to set and mark your bricks with...
        Then, I'd get a cheapo wet diamond tile saw... I recommend a 10" wet saw.. they run about $200 at Harborfreight.com (many cities have a local retail outlets).. a $60 a wet tile saw works too, they just require double the cuts since you'll have to flip your bricks each time...
        Going this way, you'll be able to buy standard firebrick and cut it to suit your needs... Angleizer includes calculations for circles, half-shere's, arches, etc...
        If you'd like to discuss further, PM me and we'll go from there...
        JB
          Thanks JB, I'll check out the angleizer this weekend. I have a good saw (Imer 14"). I talked to MK Diamand at a trade show recently & they recomended a blade that cost over 500 bucks to cut fire brick. My sawblade is a general purpose that came with the machine. I guess I'll try this first, I was going to spring for the hard blade before I bought the brick.
          Thanks for the heads up on the blade, & the invite to PM. I may take you up on it when I start cutting brick. Couple of weeks.
          Rgfds
          Balty
            For what it's worth, I wouldn't spend that kind of money on a blade unless I was in the trade and there was a return on investment for that kind of quality and price... The cheapo harbor freight blade that runs $30 has been working fine for me... Good luck.
            JB
              Even if you don't go to Harbor Freight, Home Depot and Lowes also have less expensive "use and toss" blades.
              Pizza Ovens
              Outdoor Fireplaces
                Bought my brick this weekend & decided to try a few cuts. I'm glad I didn't buy a special blade, he general purpose one cuts fire brick much easier & more accurate than I had expected & way easier than the sanded tudor brick I have been using to build the patio.
                Thks again
                Balty
                  Firebrick Question
                  I just located a local supplier for firebrick. He said he has both the yellow and red as "low duty." My question is: is the low duty ALWAYS the yellow color, or could he be right?
                  I would love to go with red if possible.
                  "You better cut the pizza in four pieces because I'm not hungry enough to eat six."
                  -- Yogi Berra
                  Forno Tito
                    JoeT,
                    Here, at least, the yellow firebrick are medium duty. The color really depends a lot upon where the original materials originate. Colors seem to vary, location to location. Alumina content is a more reliable guide. When you get a skid of firebrick here, about 15 per cent are brownish in color; these are a bit higher duty than the yellow, and I put them dead center in my hearth.
                    Jim
                      mine are "red" or reddish and low duty
                        To add my two cents worth..... If using Red clay bricks in the oven dome
                        Tap each one with trowel if they dont make a ping sound, do not use
                        them as they already have a fault in the brick.
                          OK, I am an idiot.
                          What is the best, economical way to cut firebrick used to construct to the oven? I am a masonry newbie.
                          Also, I would like to have a rectangular opening to the oven, rather than an arch. I was planning on using some sort of metal support. What are your recommendations?
                          I appreciate all the help I have gotten from this forum thus far.
                          Cheers & Many Thanks,
                          Joe
                            joe we use the red fire brick all the time in fireplaces and i used red fb split s in my oven they work fine with no burn out
                              I use my De-Walt sliding tilting angleing wood working saw, with a 12" masonry blade from Lowes or Home Depot. I cut the bricks dry.
                              I have a wet brick cutter, but I wear glasses, and after cutting one brick, my glasses are splattered and I am blind. Forget wet cutting bricks!
