FINALLY!!! - Start Of Building My Oven
  • Laurentius
    • Nov 2010
    • 923
    #241
    Re: FINALLY!!! - Start Of Building My Oven
    If one would pursue constructing a well insulated oven, why not the same with the door to make a cohesive unit? Since no wood is impervious to heat and or fire, it would highly recommended and practical to insulate it, then you would be traditional in appearance and modern in substance.
      I totally agree. However finding a suitable material as an insulating panel that is both strong and insulating enough is difficult. It also needs to be made from a material that is safe unless it is totally encapsulated. This requires a lot more time and skill. One of the advantages of a wooden door is that they are easy and cheap to make.
      • Oven_Man
        • Jul 2009
        • 221
        #243
        Thanks.
        I guess a 1.2mm thick stainless steel cut out in the shape of my entrance would work?
        Now, just to find a company that does lazer cutting.
        Is there any other way to cut the stainless steel in a arch shape with basic tools?
        OM
          stainless steel (especially thin stuff) warps considerably and easily, when heated. I don't think 1.2 mm is thick enough to prevent this. Make a cheap wooden one first.
          • Oven_Man
            • Jul 2009
            • 221
            #245
            Originally posted by david s
            If the vermiculite is a bit crumbly it will wear away so you could render over it.
            Hi David
            I hope you well.
            Just to back track a little, I decided not to wait for the Vermiculite at my entrance to wear off so I'm going to remove a tin layer from the vermiculite and then render over it. Just so we on the same page, when you say render, do you mean use the Sand:Lime:Portland mix that i used over my dome as the final layer?
            I should note that when i use the oven, this patch of exposed vermiculite gets hot, very hot in fact that you cant touch it; would that pose a problem for the render or may shall i use some Refractory Cement to run over the vermiculite sealing it once an for all?
            Regards
            OM
              It should not reach 300C which is the temp that destroys the Portland cement. It will of course be subject to expansion and contraction, but it holds up pretty well. I rendered over aerated concrete (Hebel) on my mobile oven and it has held up well. It is about 5 years old now and copped a fair bit of abuse. I have repaired a few thin cracks that developed, but if you do it yourself then it's no hassle to do some repairs occasionally.
              • Oven_Man
                • Jul 2009
                • 221
                #247
                That sounds perfect. Today, I ripped out the patch of vermicrete and replaced it with render, hope it holds up to the heat.
                Thanks a mill
                  Hi OM are you ready for fire with the beast yet?
                  • Oven_Man
                    • Jul 2009
                    • 221
                    #249
                    Hi David
                    I haven't been able to get down to do anything these past few weekends - been doing some renovations at home but definitely in the next 2 to 3 weeks - lookout for the Pics and wish me luck.
                    Take Care and keep in touch
                    Regards
                    OM
                    • Mudologist
                      • Sep 2009
                      • 25
                      #250
                      You are running into the same problem everyone faces with mobile ovens. The better you built them, the heavier they are , and the heavier they are , the better you need to build them.
                      • Oven_Man
                        • Jul 2009
                        • 221
                        #251
                        Hello FB Community
                        Been a long time since posting here but I haven't forgotten about you guys.
                        I wanted dedicate this post out to everyone here that assisted to help me build my Oven and a special dedication to David_S who has been so instrumental in almost building my oven for me with all his guidance.
                        For those that have following this thread - I'm sure you've been wondering what happened to me - did the oven ever get completed - did I scrap the project. The truth is I did finish the oven but because it's at a friends place - I don't use it very often - probably only used it about a dozen times - the cosmetics of my oven need a little facelift but the funcationlity does just as well as any good looking oven
                        I've only used the oven about a dozen times and haven't had much success in the beginning but as I learned more about the beast as David_s calls it, i learned how to tame it and found my shortfalls - it's all about temperature - I just wasn't firing her up high enough. Now my oven gets a beating out of me, I would be curious to know the temps but I don't have a term. at the moment so maybe when I invest in one I can let you guys know.
                        For your viewing pleasure - I've attached some pics of my most recent bake off which was both a success on one end (NY Style Pies) and a learning curve on the other (Neo Pies). I'm still learning so much but there's just so little time to do this as often as I like but I enjoy every bit of it when I have the chance.
                        All I can say is to anyone that wants to build their own oven - don't hesitate - go right ahead - the fruits of your hard work will sweeten once you complete a task like this and start using it's - I can promise you, its addictive. After the few bake off's we've had, I always told myself now I'm tired and don't think I can do this again and the very next day I'm craving that fire again
                        • Oven_Man
                          • Jul 2009
                          • 221
                          #252
                          And 1 more
                          • Volongo
                            • Mar 2015
                            • 17
                            #253
                            Where do I place my order? I want one! or two!
                            • Oven_Man
                              • Jul 2009
                              • 221
                              #254
                              Hi Guys
                              It's been a while since last posting here. I haven't had much use out of the oven recently - Just been too busy to even think of firing her up.
                              Recently, i've been toying with the idea of adding a gas burner to the oven and use it simultaneously. I'm looking at getting heat from the Gas and smokey note from the wood.
                              What do you guys think? Is this possible after the oven is built?
                              What size gas burner should I get? If you can tell me in BTU's, that would help greatly.
                              How do you suggest I install this Gas line into the oven? Drill through the dome perhaps and shove it in through there? Push it in from the front opening? Please give me some ideas?
                              Thanks a mill
                              OM
