Hi Guys
I hope the forum and its members are all well.
It's been a while since last posting but this post comes with great enthusiasm, expectation and courage. I know this is quite a long email but I do implore you to please read along.
I have finally decided to embark on a project to build my own Low Dome Pompeii (Neo Style) oven. I trust the Community at large will play a big part in my progress of building such an oven.The knowledge that you guys have attained over the years is priceless and I can only say that without it, my project won't go far.
I have also read posts of PFTaylor's Raquel Oven from the PizzaMakingForum and after receiving some great advice from him, I hope he will contribute as well.
Let's cut straight to the chase. To begin with, I would like to break down the manufacturing process of the oven in several parts, each part requiring unrivalled dedication and an eye for the finest detail. I would have to keep a birds eye on my bank balance (By the way, I don?t know what my budget is right now. Ill just take it as it comes). I hope to invest as much as my pocket can afford in this project so I would site every option from every angle before diving in. I want to get the best of the best in terms of Material (Hi-Tech refractory Material, etc) and I would love to build something of a world class stature.
So getting back to the task at hand. My plan of action again, is to break apart the manufacturing process of each component that would make up the oven. From the little knowledge I have gained, thanks to Forno Bravo and The Community, I would like to break it up into 3 stages, each stage consisting of 6 parts, which are listed below.
P.S Please feel free to correct anything that seems a miss. My knowledge is of the poorest form when it comes to ovens and what you may read or find may be totally incorrect.
The 3 stages are as follows.
1) Design and Planning stage - This would entail the Cad design of the oven. Simply put, this would be the building of the oven on paper.
2) Sourcing and Cost stage - I will contact various companies to source the required Material, tools, labour, etc and do cost comparison between the companies. At this stage, I will try to source the Highest Technology Refractory Material with minimal compromise.
3) Building and Implementation Stage - With the preliminary stages 1 and 2 completed, this will be easily approachable but the hardest stage in terms of Labour.
Below is the 6 parts each stage will be broken down into.
1) Hearth - Sits below the cooking deck and has insulated boards in it.
2) Cooking Deck - Sits on top of the hearth. This is the spot where pizza's will sit and bake.
3) Landing Space - Sits at the mouth of the oven. Helpful in manoeuvring pizza in and out of the oven.
4) Arch Bricks - Laid out around the deck. This is the supporting foundation for the Dome. This part may be eliminated if I can cast my dome in such a way that it can sit directly on the hearth.
5) Dome - Sits above cooking deck
6) Vent - Sits on top of dome to draw heat.
Each part above would preferably be made into a cast.
My starting point would be to plot out the design for my Heath and Cooking Deck.
I have a few questions regarding this.
What is the difference between the Hearth and Cooking Deck.
What sort of material would you guys advise to use for the Hearth?
What material can one use to cast out the cooking deck? I want something of high quality and should be able to achieve high heat and retain it
What can I manufacture the Cast Mould from to assist in casting the Hearth and Cooking Deck.
PFT mentioned his hearth having insulated boards between it or something like that. Would someone be able to explain on this further.
I look forward to hearing from everyone and hope to get the wheels rolling on this project.
Regards
Oven_Man
Regards
Oven_Man
