Re: FINALLY!!! - Start Of Building My Oven
volume of a sphere is 4/3 x 3.142 x RxR
Calculate the volume of the outer sphere (24 +3") and subtract the volume of the inner sphere (24) then divide by two because it's a hemisphere. There will be about 15% reduction in volume when you add water to the dry castable. You will also need some more castable to make the flue gallery/ manifold. You don't want mass here so make it thin.
