Re: FINALLY!!! - Start Of Building My Oven
Hi David
I asked the same guy that did my table to help me with the Peel and he has come back saying stainless needs specialized equipment to bend it, which he doesn't have. Anyways he made a suggestion that we leave the sheet as is and just weld onto it a small pieces of steel tubing and then fit the wood into the tubing.
This sounds all good but I'm concerned about the sheet being flimsy and wobbly when using the peel.
Would this be the case or is stainless steel sheeting hard and firm (Sorry i've never worked with this stuff before).
If it is going to be flimsy and wobbly, how do you harden it and make it strong a firm? I've found little info about how to harden it but one of the processes involved a high heating of the metal and them a rapid cooling of it.
Would my Pizza Oven be able to this for me, they suggest a Kiln but I'm sure i can heat my oven up to extreme temps as well.
I also know with normal mild steel, bending the sheeting will cause it to harden.
Is this the case with Stainless Steel as well?
Regards
OM
Hi David
Regards
OM
