I am planning to build a wood fired oven. I consider myself an inept brick layer.How difficult is it to build? should I go to a precast refactory dome instead?
Pompeii Oven
Tags: None
I am pretty sure that most people start this project with little or no brick laying skill (I know I did). You learn along the way, and frankly, it doesn't have to be perfect...
If you can afford the precast dome, it is sure easier as the stand itself is quite a lot of work. But then you don't get the "pride of authorship"...
DrakeMy Oven Thread:
http://www.fornobravo.com/forum/f8/d...-oven-633.html -
Pompeii
Thanks Drake, I like authorship!I havent investigated all I need to, but I'm leaning toward a brick oven. Thganks JackOriginally posted by DrakeRemorayI am pretty sure that most people start this project with little or no brick laying skill (I know I did). You learn along the way, and frankly, it doesn't have to be perfect...
DrakeComment
Inept is ok
If you are beginning the project as an inept brick builder that's probably better than many of us who built a brick dome. I started the project with credentials of inept floor tiler, no brick experience. It takes more courage than skill. This forum and the wonderful Pompeii plans gave me all the information I needed.
Have fun!Comment
