Basic nonrefractory brick mortar recipe?
  • kebwi
    • Aug 2009
    • 1090
    I need to make a very short brick wall (4" high, basically single "pavers" on their edges). It won't be exposed to heat. What would be the right mortar recipe? I assume it is basically the same as the home-brew but without the fire clay. Something along the lines of 3:1 sand/portland or 3:1:1 sand/portland/lime. I have no idea.
    Any ideas?
    Re: Basic nonrefractory brick mortar recipe?
    4:1 sand, cement is normal. Usually no lime, it is extremely drying on bare skin. Better to use a squirt of dishwashing detergent to make the mixture more sticky.
    • kebwi
      • Aug 2009
      • 1090
      Well, I do all my mortar work with masonry gloves anyway, but if lime isn't usually in the mortar for structural reasons, then no problem. I feel compelled to use this enormous bag of lime I bought. My argument for or against lime wouldn't be based on skin exposure, but rather on the correct way to bond bricks. Is lime still not appropriate then? Just 4:1 sand/portland?
      Thanks.
      • Tscarborough
        • Oct 2009
        • 3341
        1p,1/2l,2-3s is type N mortar. Never,ever put soap in it.
        You need thinset for your app.
        • kebwi
          • Aug 2009
          • 1090
          May I assume that you recipe is "thinset" then...or were you suggesting I buy premixed labeled thinset despite the inclusion of a recipe in your post?
          Sorry for the confusion, just trying to be clear.
          • cannyfradock
            • Nov 2009
            • 96
            Kebwi
            Apart from it's thermal properties, lime is only usually added to sand and cement to act as a plasticiser so as the mortar can be more easily applied to walls for rendering/stucco applications.
            Normal mortar mix(in any country) as David S said is 4:1. Liquid plasticiser is then added to give it workability. 3:1 would be to strong as the mortar should never be stronger than the masonry that's it's holding together. General principle being that if there's ever movement, the weakness should come in the mortar in a diagonal movement (repairable) as opposed to a vertical fissure which goes through mortar and masonry. Not that this is anything to do with 4" brick pavers laid on edge. As per David s is perfect.
            Terry (C.F)
            Honi soit qui mal y pense
            My 2nd Pompeii build.....
            http://www.fornobravo.com/forum/memb...eii-build.html
            • RTflorida
              • Jan 2007
              • 1446
              Keith,
              not being a professional mason, my opinion may not be of much value, but here goes.
              Since I am not a mason (no offense, you are not either - we simply like doing our own projects) I have always prefered the ready mix products. Why worry about "what mix is best?" or "did I get the ratios right?" I have done several dozen projects requiring some sort of cement based product - brick, block, wall tile, floor tile, stone, (you get the idea). NEVER have I bothered with mixing my own (except the perlcrete and vermicrete in my oven insulation).
              Its always been one of 5 products depending on the application - basic thinset, fortified thinset, premix concrete, Type S mortar, or Type N mortar. Type S or N for all outdoor applications. Not bragging, but I have never had a joint fail or crack in 25 yrs or "projects" (except an arch joint that keeps reoccuring - Heatstop 50), no tile pops, no stone or brick come loose.
              For the minimal cost of a bag of Type S or N (maybe $15), why not remove the guesswork?
              The premix stuff was meant for guys like us....its not rediculously priced and it REALLY works.
              RT
              • Tscarborough
                • Oct 2009
                • 3341
                Sorry for the confusion, Kebwi, thinset is your best bet, the formula is the standard for Type N mortar in reference to the post suggesting the use of soap as a plasticizer.
                • Tscarborough
                  • Oct 2009
                  • 3341
                  "Normal mortar mix(in any country) as David S said is 4:1. Liquid plasticiser is then added to give it workability."
                  That is interesting. Do you have any tests and standards as to dosing for the plasticiser? In this part of the world, they are not common or available in DIY quantities.
                  Here is the relevant standard: ASTM C-270, that is used in the US to determine mortar composition:
                  How Is Lime Specified Into Mortars?
                  It can be done either by proportion or by property, using plasticizers would force the mix design to be done by properties.
                  • kebwi
                    • Aug 2009
                    • 1090
                    I'm a little confused. I realize I'm just making a stupid 4" tall wall so it probably doesn't make any difference at all, but I just want to understand.
                    It was suggested that I should use thinset to hold the bricks of this dinky wall together and to hold them to the base (the terraces).
                    First, I'm not sure if thinset is something I make or buy. I know I *can* buy it, but I'm not sure if it is something I can make with the materials already available to me (basic sand, portland I/II (HD's is described as both I and II), masonry lime, (and fireclay but that obviously isn't relevant).
                    Second, everything I see on line describes thinset as being used to glue tiles to a wall...which what I had always thought thinset was for, that was the only context I had ever heard it in before.
                    Why would we use thinset to mortar bricks together instead of "brick mortar", whatever that would be? I'm thinking of must just mixing sand and portland about 4:1 and "gluing" the wall together that way (and I guess not including any lime, or I dunno, I had thought, whatever, I don't understand lime at all after this project). Anyway, wouldn't 4:1 work for making a one-level wall? And more importantly, would that not be described as thinset? Would it be something else?
                    What makes thinset thinset and not brick mortar?
                    • cannyfradock
                      • Nov 2009
                      • 96
                      Kebwi
                      Sorry for any confusion on my part. Although principles may be the same, materials differ from country to country so I should'nt really post comments.
                      Have been following your build (36" in Seattle) from early on and have been truly impressed with every stage of your wood-oven build.From your early graphics to your photo diary and vidio's to the tiered effect you are doing now. A brilliant thread to follow.
                      Terry (C.F)
                      • Tscarborough
                        • Oct 2009
                        • 3341
                        Thinset has finer aggregate so that in can be set thin (1/16-1/8") as opposed to mortar which is 1/4-3/4" thick. It also usually contains acrylic or latex modifiers to make it stronger (6-12,000 PSI, as opposed to 300-3000 PSI for brick mortar). It costs about 12 bucks a bag at the big box stores.
                        • kebwi
                          • Aug 2009
                          • 1090
                          Thanks guys. I always appreciate the information. I'll take it all in stride.
                          Cheers!
                          • Tscarborough
                            • Oct 2009
                            • 3341
                            This appears to be the mortar standards for the UK: PD 6678:2005
                            I can not find a copy of it online or even a summary. Do you have access to a copy, Cannyfradock? This type of thing is my hobby as well as my profession, and I am always interested in learning more.
                            • cannyfradock
                              • Nov 2009
                              • 96
                              Tscarborough
                              Since serving my apprenticeship in 1978 building regs and procedures have changed many, many times over the years. With the ever changing policies in building procedures and practices it is now up to the cement companies to deliver the correct mortar for the type of brick and location of the build, and it now arrives in ready mixed quantities with retarder to be used over a period of days.(large multi-house sites)
                              As regards mortar standards for the UK: 6678:2005. This has long since left the control of the builder of the property and now is in the hands of the white-collar brigade and cement manufacturer.
                              This is just a courtesy post to yourself in regard to your last comment and I hope that has answered your question.
                              Regards......Terry (C.F)
