Re: Basic nonrefractory brick mortar recipe?
Yes, I saw that when researching it. We have a similar product here, generally called "Spec-mix". It is a very good product, and in some areas utilizes plasticizers instead of lime. Regardless it still has to meet the ASTM C-270 standard, and I was interested in that, i.e. what physical properties and strength is the mix design based upon.
Ultimately it is always up to the mason in the field to determine the suitability of the mortar within jobsite conditions and parameters. Usually this will only involve how much water is added when using silo mortar, but for any job not using premixed mortar, there have to be guidelines to determine the composition of the mortar (as well as methods of testing and quality assurance).
