I'm hoping to get my insulation blanket put over the dome this weekend. Any advice for the best technique to use for the layout? I figure the gang here has some tricks for laying a flat blanket over a dome.
I have 2 x 1" x 50 sq ft (24" wide) of blanket to use and am hoping to end up with 3-4" on top and 2" on the sides.
I was thinking of starting with a horizontal piece across the top and then wrapping a vertical piece around the whole base with some cuts in the top half to overlap sections. And then repeat those 2 layers again.
Thanks for any ideas.
